586,077 active members*
4,039 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Understanding Fanuc window functions
    Nov 2020
    Hello,
    I'm a bit of a beginner to this so please bear with ... I have a Fanuc 30i and I'm trying to understand how to implement sub51 to read parameters to an R address which I then want to access in ladder. My issue is I don't understand how to reference each parameter using the window function. Basically I would like to know if anything on the first page of the parameter screen has changed from 0. Would anybody be able to give me an example of a window function setup in R addresses starting at R2600 for instance, for the bits highlighted with red squares in the attached image please.
    TIA !!!!!
    Re: Understanding Fanuc window functions
    Fanuc doesn't allow you to read bits. You must read the whole byte (Bit 0 - 7). Being that you have 0's in all the parameters then reading is simpler. Here is the ladder I came up with. I didn't test this so you might have to tweek this. Also I had to change the ZONETEST.LAD to ZONETEST.txt so the Zone would allow me to attach it so rename it ZONETEST.LAD before opening
    Nov 2020
    Thanks a lot for this. I'm just going over it now, I'll get back to you once i've managed to get my head around it! cheers!!!
    Dec 2015
    171
    Hi chas00 could you please help me? I need Fanuc 31i-Ta & 32i-TA system and backup files? If possible could you please share with me.
    [email protected]
    Aug 2019
    145
    For many functions of the NC there are corresponding F bits for status in the PMC. As an example F110 is the status bit for Detach which a part of parameter 12.7 function. Have you checked to see if there are possibly F bits for the functions you are trying to monitor?
    Sometimes windows are the only way, but I try to limit usage whenever possible as they pose their own unique challenges.
  1. Understanding "5-Axis Functions" window
    By declanhalpin in forum MadCAM
    Last Post: 10-02-2015, 09:31 PM
  2. sub51/sub52(window functions)
    By dimka76 in forum Fanuc
    Last Post: 09-22-2015, 02:10 AM
  3. FANUC CNC - WINDOW Function WINDR
    By mebugayan in forum Community Club House
    Last Post: 09-17-2013, 09:21 PM
  4. Replies: 0
    Last Post: 11-09-2009, 06:25 PM
  5. Replies: 2
    Last Post: 02-03-2008, 03:45 PM
