586,655 active members*
3,485 visitors online*
Results 1 to 9 of 9
    Jul 2006
    12
    Question TTS R8 collet
    Are there any alternatives to purchasing an R8 to TTS collet from Tormach?
    $39.95 seems really steep for a simple R8.....
    Apr 2013
    1788
    Re: TTS R8 collet
    The end of the collet needs to be flat rather than slightly convex as with most R8 collets. I seem to recall that someone posted an alternate source a few months ago. I suppose that you could grind the end on a normal collet to be flat.
    Aug 2016
    132
    Re: TTS R8 collet
    Tormach chops 100 thou or so off the end of the collet to recess it in the spindle now. Other than that, it's a standard 3/4" R8 collet, which can be bought from anyone.
    Jul 2006
    12
    Re: TTS R8 collet
    Do ya know if their collets are close enough to be able to use more than one, and still use the same tool offset?
    Or are there collets one-offs?
    oh, thanks for the replies.....
    Apr 2013
    1788
    Re: TTS R8 collet
    The collets do not affect tool offsets. The collet nose is flat which allows the rim of the TTS holder to contact the spindle nose which gives a consistent offset.
    Oct 2012
    42
    Re: TTS R8 collet
    A word of warning. Having tested lots of collets there is wide variation in hole parallelism and TTS contact area when the collet is gripping. TTS is dependent on full length gripping the 3/4 shank and some collets only grip one end or the other of the shank.
    Oct 2017
    62
    Re: TTS R8 collet
    I'd think you'd need a different offset for different collets. TTS nets off the ground surface after the collet is drawn hone with a 3/4" tool in place. Multiple collets would need to be identical from the taper to the nose.
    Bruce
    Apr 2013
    1788
    Re: TTS R8 collet
    I don't believe that you are correct. A properly functioning TTS holder is gripped by the collet but its vertical position is solely determined by the spindle nose.
    Oct 2017
    62
    Re: TTS R8 collet
    Yes, you are correct. The TTS collet draws its nose up into the spindle, so the datum surface is the surface of the spindle, not the collet end. My mistake, thanks for setting me straight!
    Bruce
  1. TTS R8 collet, when to replace?
    By jcposada in forum Tormach Personal CNC Mill
    Last Post: 06-30-2015, 03:08 PM
  2. Tormach TTS R8 Collet Engagement
    By sperman in forum Tormach Personal CNC Mill
    Last Post: 02-12-2014, 05:29 AM
  3. TTS Collet Size
    By R.M.S. in forum Benchtop Machines
    Last Post: 01-28-2014, 12:20 AM
  4. TTS Collet Holders shorter?
    By skray775 in forum Tormach Personal CNC Mill
    Last Post: 07-09-2012, 04:23 PM
  5. R8 collet and TTS system
    By FandZ in forum Uncategorised MetalWorking Machines
    Last Post: 05-09-2010, 07:42 PM
