587,098 active members*
5,610 visitors online*
Results 1 to 7 of 7
    Mar 2011
    525
    TTS Collet Holders shorter?
    Hi all
    Have any of you noticed the new batch of ER collet holders are shorter by about .5" ?
    Kelly
    www.finescale360.com
    Oct 2007
    269
    Saw a sticker marked "OLD" on the last four recently received. They were still oily and sealed in the factory bag, obviously new, but had me curious. I'll check to see if any are different.
    Jim
    Mar 2009
    1863
    Shorter holders are good. I like to use the ER16 collet holders on most jobs because I like short holders and once I get my coolant line set, I don't have to keep moving it around to keep coolant on the cutter/part. But after seeing what Rory at Tormach did to his coolant line I'm going to do the same thing, then the coolant line doesn't move up and down with the Z axis.
    I make a couple of parts where I have to keep the coolant line in one place because I am drilling a 1/8 inch diameter hole 4.5 inches deep.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Mar 2011
    525
    Not complaining just wondered if I missed a selection at order time.
    Here is a picture, original, taller ones on the left, newer shorter ones on the right.
    Kelly
    Oct 2007
    269
    Checked them out, including the four recent ones, and all are the longer "OLD" style. Thanks for the heads up on this, as I was getting an order ready with few of them on it. They'll even out some of the longer tooling.
    Jim
    Jul 2007
    1602
    Quote Originally Posted by Steve Seebold View Post
    Steve,
    Do you have a link to this?
    bob
    Mar 2009
    1863
    Quote Originally Posted by rowbare View Post
    Steve,
    bob
    Go here:
    ATC Owners: What is your coolant set up?
  1. Where can I buy tool holders/ collet chucks??
    By tomekeuro85 in forum Community Club House
    Last Post: 07-05-2010, 06:46 PM
  2. modifying Carbide endmill shanks"cutting them shorter"
    By kojack in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 05-26-2009, 05:08 PM
  3. Consumables...life shorter with a water table?
    By carbidecraters in forum Waterjet General Topics
    Last Post: 06-05-2008, 06:36 PM
