603,311 active members*
3,391 visitors online*
IndustryArena Forum > Other Machines > Commercial Products / Manufacturers Support Forums > Automation Technology Products > Running DDCS CNC Motion Control System with MPG, NEMA 23 Stepper Motor
Results 1 to 1 of 1
Hybrid View
    https://www.youtube.com/watch?v=-jB_aiuNiN8&t=2s
    DDCS CNC MOTION CONTROL SYSTEM WITH MPG, NEMA 23, 2 AXIS
    Product Link:
    https://www.automationtechnologiesin...system-nema-34
    This system is assembled and tested. It is ready to run.
    We can also update the system to 3 or 4 axis, or change to NEMA34 stepper motor.
    Please contact us if you need.
    E-mail: [email protected] Phone: 847-984-0882
    Product Included:
    1pc DDCS Motion Controller with MPG
    2pcs KL23H2100-50-4BC Stepper Motor, 12 ft cable
    2pcs KL-5056E Digital Stepper Motor Driver
    1pc 48V/12.5A Switching Power Supply
    1pc 24V/2A Switching Power Supply
    2pcs Inductive Proximity Switch, NPN (extend to 12 ft cable)
    1pc Aluminum Box
    1pc Power Code & USB Extension Cable.
    Features:
    The DDCS numerical control system adopts the ARM+FPGA design framework. The ARM can finish the part of human-computer interface and code analysis and the FPGA can finish the part of underlying algorithm and control pulse generate, with the reasonable design, reliable control and easy operation.
    The panel layout structure of DDCS is rational. The common off-line operation can be finished only by 17 keys and it supports the FANUC with high universality to be compatible with G code set. This specification introduces the operation method of caving machine’s special off-line CNC system, DDCS and the machine tool connection as well as operation specification. By lots of graphical representation and examples, the uses can quickly learn to use the DDCS CNC system.
    Attached Thumbnails Attached Thumbnails ddcs1.jpg   ddcs2.jpg   ddcs3.jpg   ddcs4.jpg
  1. DDCS Motion Control System with MPG, Testing with NEMA 34 Stepper Motor
    By automationtechinc in forum Automation Technology Products
    Last Post: 08-18-2021, 10:03 PM
  2. 3 Axis EtherCAT NEMA 23 CNC Motion Control System with Mach4
    Last Post: 06-22-2021, 03:09 PM
  3. Testing CNC Motion Controller (500KHz) DDCS V3 CNC Control
    Last Post: 06-13-2021, 08:10 PM
  4. Replies: 0
    Last Post: 12-17-2013, 01:14 AM
