586,115 active members*
3,476 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Trouble with model
    Aug 2012
    71
    Trouble with model
    Hello All,
    I have constructed a fixture to hold a part for machining. I extruded off the original model.
    I now want to get rid of the original model and save only the fixture. I delete the model and the fixture goes with it.
    How does one deal with this?
    TIA,
    FMJ
    Feb 2006
    196
    Re: Trouble with model
    Are you in an assembly (.sldasm) or part file (.sldprt)?
    Doug Pryor
    David Wolfe Design, Inc.
    Akron, OH
    www.davidwolfedesign.com
    [email protected]
    Aug 2012
    71
    Quote Originally Posted by dpryor View Post
    I am in the part file.
    Aug 2011
    252
    You can`t delete the original model once you have extruded from it, because that extrusion is dependent of your original.
    I think what you want to do is to cut in fixture with original model that need to disappear after that, I assume you have two bodies, so you can use COMBINE - SUBTRACT one from another.
    Feb 2006
    196
    Once you no longer need the original part, you can open the "SOLID BODIES" list and delete the corresponding body. See attached.
    The "DELETE BODY" then becomes a feature at the bottom of your tree.
    Doug Pryor
    Akron, OH
    [email protected]
  1. Replies: 2
    Last Post: 04-24-2018, 09:48 AM
  2. Replies: 4
    Last Post: 04-03-2018, 07:21 AM
  3. Trouble with fanuc 31i model b5
    By jdeaton01 in forum Fanuc
    Last Post: 11-21-2017, 03:33 PM
  4. Trouble cutting circles. Trouble with y-axis
    By chrisv7 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-08-2016, 09:43 PM
  5. Manuals for Wasino Model LG-71 Turning Center and Mori Seiki Model MV-40B VMC
    By innovativeiron in forum Machinery Manuals / Brochures
    Last Post: 11-07-2013, 02:28 AM
