603,323 active members*
3,601 visitors online*
Hybrid View
    Dec 2011
    63
    Questions on Win7 and Mach 3
    Hello. I'm trying to use my old Mach 3 xml file on a newer Win7 computer with SP1. I"m using the same LPT printer card/cable which worked before. My Mach 3 and Gecko 540 setup is working as recommended. But when I connect the LPT cable nothing works as it should. I sometimes get a BSOD when I close mach 3. I also get a BSOD when I try to use the Utility for checking the OS frequency. Are there some specific MS run-times I might need? I'm wondering if my LPT pci card might be bad.
    Apr 2004
    5948
    Re: Questions on Win7 and Mach 3
    Is it a 64-bit OS? Mach3's parallel port function needs a 32-bit OS, and won't work with 64.
    Andrew Werby
    Website
    Dec 2011
    63
    Hi, Andrew. Yes, it's Win7 X86. But thanks. I'm going to get another LPT card, with driver, and see what happens. Yet another delay when I need to get this up and running asap.
    Dec 2011
    63
    I found out that my internal LPT card was bad.
  1. USB Smoothstepper WIN7 install: Crashing Mach 3 - need help please.
    By demonx in forum SmoothStepper Motion Control
    Last Post: 12-12-2014, 05:50 AM
  2. Couple mach 3 questions
    By vtx1029 in forum DIY CNC Router Table Machines
    Last Post: 03-12-2012, 03:08 AM
  3. Mach 3 Questions
    By tz1238 in forum Machines running Mach Software
    Last Post: 01-12-2008, 06:08 PM
  4. MAch 3 questions
    By elogicca in forum Mach Mill
    Last Post: 06-07-2006, 06:59 PM
  5. Mach Questions
    By tsutt in forum Mach Mill
    Last Post: 02-13-2006, 07:27 PM
