603,836 active members*
2,742 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Setup sheet in Gibbs cam
    Jan 2007
    61
    I would like to be able to have my tool list and a picture of the part with some added text. What I would like to to do is have it put on 1 page of a pdf, so each time the job is run the setup notes can be printed with 1 click. I printed the tool list ,put the paper back in, and printed the picture with notes, then scanned it all to pdf. This works but is there a way to say take a screen shot and put that in a pdf? or is there a beter way for setup sheets? I dont really care for the reports from gibbs.
    Thanks, binzer
    Apr 2004
    354
    There is a way to make setup sheets using Microsoft Excel. You'll have to read through the manuals to understand it better. Basically Gibbs has a number of 'variables' that you can export to specific cells in Microsoft excel.
    If you go to Plugins -> Reporter 97, 2000, or XP there are a few that come with Gibbs that you can check out.
    Jun 2003
    513
    You can pretty much create any kind of setup sheet you want or modify any of the existing ones in Gibbs. Gibbs uses Excel. There are instructions in help and I think there is a tutorial too. To save them as a PDF all you need is a PDF creation application on your computer (I use CutePDF, cheap) and print the setup sheet to your PDF application. No need to save screenshots.
  1. Example CNC machine Setup Sheet + program backup
    By lug_wrench in forum DNC Problems and Solutions
    Last Post: 12-28-2015, 06:37 PM
  2. Setup Sheet Problem
    By StormWerkz in forum Mastercam
    Last Post: 03-21-2007, 04:24 PM
  3. operation time estimate in setup sheet ?
    By andy55 in forum Mastercam
    Last Post: 10-06-2005, 06:14 PM
  4. Mastercam Setup Sheet Help
    By stampman in forum Mastercam
    Last Post: 02-27-2005, 02:54 AM
  5. How to change the setup sheet format?
    By cwww in forum Uncategorised CAM Discussion
    Last Post: 06-30-2004, 08:28 PM
