586,103 active members*
3,799 visitors online*
Results 1 to 10 of 10
    Aug 2007
    215
    pros and cons
    Two stepper motors: RHT23-260 and FL57STH76. Both NEMA23 both rated at 260 oz/in holding torque. Both physically the same dimensions or therabouts.
    The RHT23-260 is 3.2V @ 2.8A/phase and inductance 3.6mH
    The FL57STH76 is 4V @ 2A/phase and inductance 6.4mH.
    Can anyone compare and contrast these for me please?
    Jun 2003
    3312
    All things being equal and reasonable (driver, powr supply, etc) The RTH should give you better performance as you go up in step speed, due to the lower inductance and lower coil voltage.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Aug 2007
    215
    cool - so far 1 nil to the RHT - anyone want to back the FL5?
    Jan 2006
    245
    The RHT will perform better at higher speeds due to the inductance.
    But is the current and inductance you mantioned in series, parallel or unipolar?
    our unipolar and parallel inductance is 1.6 mH.
    If the figures you mentioned are unipolar or parallel figures the FL57 will most likely perform better.
    Quote Originally Posted by stirling View Post
    Motion Control Products Ltd
    www.motioncontrolproducts.co.uk
    Jan 2006
    245
    Aug 2007
    215
    Quote Originally Posted by mcpltd View Post
    Thanks for this - when I originally posted I didn't have the extra spec that you provided (so apologies to pminmo if that would have affected your answer). mcpltd - You've confused me slightly though with your last statement.
    The figures I've mentioned are serial according to your data sheet - so do you mean if I were to configure unipolar or parallel then the FL57 would be better?
    Jan 2006
    245
    What i meant was if the inductance figures you mantioned for the RHT motor were parallel or unipolar ratings then things would be different, and the FL57 motor would most likely perform better because the FL57 in parallel and unipolar are 1.6mH.
    Because the RHT motor is 3.6mH in series this will most likely perform better, but connecting is parallel the difference is minimal, and then it is good to look at the price difference.
    It may also be worth looking at hte FL60STH86-3008BF? This motor is 3Nm HT.
    Aug 2007
    22
    Picstep Current ?
    Hiya all just finished my picstep board working champion ;-)) Thank you Alan !!! 1 question i have a 16K used as the current limit no matter what i do to the motor it wont run above 600ma was wondering if the pic is limmiting the LMD18245 or if the current is control by the PIC ? thanks
    Aug 2007
    22
    Picstep Champion
    Think Alan needs a donation from all that use his board. Just a thought Been playing around with speed torque etc the whole weekend using FL86ST134 motor 5.6 amp motor and it runs like magic. On too my next s boards Will post some jpeg's 1-3 boards L6203 L238 Then the picstep board
    Attached Thumbnails Attached Thumbnails Picture 006.jpg   Picture 003.jpg   Picture 005.jpg
    Aug 2007
    215
    welcome to my thread dalescnc - not sure what posts 8 and 9 have to do with the my question - but hey - nobody else seems to be forthcoming so thanks for your input - I'll bear it in mind when choosing my next motors
  1. Plasma vs Torch- Pros & Cons - Looking to buy
    By txcowdog in forum Waterjet General Topics
    Last Post: 11-15-2006, 06:41 AM
  2. Slaved Motors Pros & Cons
    By destro in forum Waterjet General Topics
    Last Post: 07-18-2006, 03:28 AM
  3. Pros and Cons (4 Post Design)
    By BuckingFastards in forum DIY CNC Router Table Machines
    Last Post: 03-22-2006, 01:30 AM
  4. Pros and Cons of Two Designs
    By PaulH in forum DIY CNC Router Table Machines
    Last Post: 10-22-2005, 03:22 PM
  5. What are the pros and cons of
    By cncadmin in forum CNC Machining Centers
    Last Post: 05-19-2003, 06:31 AM
