586,692 active members*
3,058 visitors online*
Results 1 to 12 of 12
    Apr 2011
    131
    Ball screw returns
    I have an old IBL ball screw. I took it apart to repack it and one of the 3 returns is in sad shape.
    It looks like it's melted on the outside and there is a hump on the inside.
    I've never repacked a ball screw before so I don't know how much of an issue this is.
    IBL (International Ballscrews Limited) were bought by Danaher (who also owned Thomson) and were known for a while as Thomson-IBL. It's not clear to me if there is a current connection with ThomsonLinear. I asked ThomsonLinear and they basically said we need to see a company website before we'll talk to you.
    One option that occurred to me is to just grind out the hump with a micro dremel bit and try and reinforce the back side with some kind of filler.
    I sent an email to ablservicesltd.com (UK) as their page says "A B Linear was born of the demise of Thompson IBL and therefore has an ingrained understanding of the product with over 20 years within their manufacturing team. A B Linear has an extensive stock of Thompson IBL ballscrews and parts and can carry out prompt and timely repairs for all Thompson IBL ball screws." We shall see. They may only do mail in repairs and this is something I feel I can just fix myself with new returns.
    Again, this is the first time I've ever taken a ball nut/screw apart so I'm learning. If something above is idiotic on my part, apologies :-)
    15362
    Re: Ball screw returns
    Quote Originally Posted by crazybrit View Post
    I thought International Ballscrews was still in business.
    The first photo is that the back side of photo # 2 or are they separate pieces
    Mactec54
    Apr 2011
    131
    Not that I am aware of. And there are just 3 plastic pieces. One photo is the backs of the 3 returns, the other the "fronts" of the same returns. Same left->right ordering in each picture.
    I suspect replacements could be 3D printed. Not sure what material, nylon I expect for durability. Advice welcomed.
    15362
    Ok that makes sense, it looks like the screw was run to fast and melted the plastic, or a solvent was used that attacked the plastic, 3D printing would not be good enough for this part unless you could use a high temperature tough plastic, and I don't think the normal 3D printers can use these type of engineering plastic needed
    They could be made using Peek, which would be the ideal material or AF Delrin may work, they could be machined
    Mactec54
    Apr 2011
    131
    Prusa i3 mk3 can print delrin with some tweaking. Or so I read.
    But it may be easier to try and bodge the current setup, so the mill can be got running to then machine new ones out of delrin.
    15362
    That would be a way to do it, I would use the Peek material over the Delrin, a 3D printed Delrin would be to soft, without carbon fiber added. If you are going to machine new ones then use Peek
    There are some epoxy's that can get very hard, like Moglice which is expensive but would do the job until you could make some new ones
    Mactec54
    Apr 2011
    131
    Quote Originally Posted by mactec54;2475246 I would use the Peek material over the Delrin, a 3D printed Delrin would be to soft, without carbon fiber added[/quote[
    First, thanks for the advice, greatly appreciated. Second I assume you're recommending plain polyetheretherketone (the beige color) not the carbon or glass reinforced version (I guess delrin is available in reinforced also).
    [quote
    I was pondering JB weld. I need to build up the backside (opposite where the balls run) as otherwise it's going to push back out and impede ball return. As far as the pump I was going to try and heat it and push it back in, else grind it off I guess.
    I also need to reball it. I should probably do that (or at least inspect the existing balls under a microscope) before putting back in the modified existing returns .... so I can make new ones.
    15362
    If you only need to build up the back then JB would do the trick, if you need any in the track that would be to soft, in the track you could drill a hole right through and put in a plastic plug ( tight fit ) and profile it to the shape you need on the inside, epoxy on the back side
    Mactec54
    Apr 2011
    131
    You're full of good ideas. Thank you. I'll see if it will push back with heat, else drilling is a good idea and I'm sure just nylon would be fine for such a small area.
    15362
    There is no load on them they are just a guide
    Mactec54
    Aug 2009
    1573
    ...machine shop 101...need more engineers.
    ... du lernst immer übers probieren. das nennt man erfahrung.
  1. Double ball nut worth it for long C7 grade rolled ball screw?
    By salukikev in forum Benchtop Machines
    Last Post: 09-02-2021, 07:48 PM
  2. Play in ball screw with anti backlash ball nuts
    By chesty012003 in forum Linear and Rotary Motion
    Last Post: 08-20-2021, 07:27 AM
  3. Ball nut arbor size for 1605 ball screw
    By kdoney in forum MetalWork Discussion
    Last Post: 04-08-2020, 07:45 AM
  4. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 05:15 PM
  5. Big Ball Screw & Ball Nut mistake.
    By Jack F in forum Uncategorised MetalWorking Machines
    Last Post: 04-29-2006, 04:53 AM
