603,942 active members*
4,063 visitors online*
    Apr 2003
    96
    Using old hard drive to copy Mach3 Config file
    Hello all, My computer that I was running Mach3 on died, but the hard drive is still good. I was wondering if I put the old hard drive into the other computer that I will now be using and copy the config file I have on the old hard drive to the new one, will I have to do anything in Mach3 to recognize my cnc machine?
    Thank you for all the help!
    Eric
    Nov 2008
    644
    Re: Using old hard drive to copy Mach3 Config file
    Mach3/4 uses a XML configuration files to define all parameters of your machine.
    That would be handy to back up if you need to run Mach from a different machine.
    If you don’t have a backup and the drive works…. You can either go to a computer repair shop and have them copy the drive into a large USB memory stick or buy an adapter that plugs into your old drive that also plugs into your USB port.
  1. Just got my Zenbot 4896 - Mach3 config file needed
    By FelixK in forum Zen Toolworks
    Last Post: 05-01-2021, 11:27 PM
  2. SV-503 Copy from Hard Drive(card) to Memory
    By smecher in forum Mori Seiki Mills
    Last Post: 05-22-2014, 09:32 PM
  3. A2100 hard drive dead. Can I copy our other machine?
    By Larry Callahan in forum Cincinnati CNC
    Last Post: 09-16-2012, 02:57 PM
  4. Mach3 Config file
    By ltcjr71 in forum Charter Oak Automation Support Forum
    Last Post: 12-17-2010, 02:57 AM
  5. Copy from Hard Drive to Memory
    By cpmfastools in forum Haas Mills
    Last Post: 03-26-2010, 08:28 PM
