586,105 active members*
3,248 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > Can't eliminate backlash, please help
Results 1 to 10 of 10
    Jun 2021
    6
    I built the Further Fabrication laser and I can't seem to get rid of the backlash on the longer axis. It makes my circles look like crap, check out the attached photo. I have been chasing this problem for months, I have tried many different configurations of the drive on this axis to eliminate any slop, and I've aligned the laser countless times.
    Is a 1.5 meter loop of 9mm wide timing belt(3m total length) just too much length on the belt? Do I need to get some kind of stiffer drive system? Am I just not aligning the laser to the level of perfection required? If I didn't have so much money sunk into this machine I would've gave up by now.
    Nov 2008
    643
    Re: Can't eliminate backlash, please help
    X axis is right left and Y axis is forward backwards as you stand in front of the machine. So if the photo were orientated top bottom of the page to X+ and X- then the X axis appears delayed.
    Assuming this is belt driven, you don’t have to have tight belts. Just snug should do. Also shafts in pulleys need to be tight with no play when you twist them by hand.
    What resolution do you have on your stepper drives? Can you go to the highest setting?
    You need to change the machine configuration if you mess with these settings or you dimensions will all be wrong.
    Jun 2021
    6
    I have checked the belts and pulleys a million times and played with levels of tightness from rubber band to guitar string. I will check the step resolution and try turning it up
    Jun 2021
    6
    Ok i tried doubling the steps per rev from 6400 to 12800. sadly it doesn't help. i'm beginning to convince myself the belt is no good. checked the tension again, it's good
    Nov 2008
    643
    Ok good that’s now set. I think it a good idea to try posting the circle some other way.
    Process it with different gcode or something. Don’t know if your using a DSP controller, Laserburn or what.
    Check what happens if you take the cut in the opposite direction.
    Jun 2021
    6
    I'm using a ruida controller with lightburn and rdworks, tried them both, they both have the same problem
    Mar 2009
    1982
    I would advce to find out the root of the error.
    what is accuracy and repeatability of axis positioning? That's the point to start from.
    Nov 2008
    643
    Just to see what happens when i loosen up the X axis belt by about 10mm. So it was loose but the teeth were still engaging on the pulley.
    then cut a 75mm circle. I compared it to a circle cut with a tight belt (the circle is very round as I can spin it in the wood) and found the loose pulley circle to be distorted slightly.
    I'd say about a half mm in the two sections as shown on the attached photo. So I'm not getting what you are seeing. I don't think the problem is mechanical.
    Jun 2021
    6
    Dean448, that's very interesting, I wonder what the problem could be then. I remember seeing a post about a stepper setting that can cause you to lose a step when you change direction but I didn't think that would make enough of a difference to be visible. Now I'm wondering if it could be a software problem. I'll try to find the post again.
    https://lightburnsoftware.github.io/...ringRuida.html
    I found it but on a second read it looks like it produces skewed engravings so I'll test that when I can but I don't that that's it. Are there any common laser test patterns that help diagnose mechanical problems?
    Aug 2021
    17
    1. The better, if your bełts will be not enough tight, then overtight.
    2. Check movement by hand for big circle. If you haven't any troubles, or torgue change, then, your movement system is ok.
    3. Check focus distance between raw material and laser head. It must to be +-equal for all of it. Last time i've found, that my table is really deformed, so i just install it on big aluminium block ))) 600x400x20mm. The Beam distortion problem was rejected.
    4. Please, engrave the big rectangle and octogon.
    Show the result.
    4.
  1. Options to eliminate backlash?
    By cnczoner in forum Linear and Rotary Motion
    Last Post: 01-31-2013, 06:44 PM
  2. Getting facets on curves, how to eliminate?
    By BaxterB in forum Mastercam
    Last Post: 09-13-2012, 06:50 AM
  3. Is it possible to eliminate wire nubs?
    By chubby hubby in forum EDM Discussion General Topics
    Last Post: 07-18-2012, 12:05 PM
  4. Eliminate the Air Cut!
    By CyborgCNC in forum Mastercam
    Last Post: 02-03-2012, 05:49 PM
  5. How to eliminate backlash ?
    By Ashish B in forum CNC Machining Centers
    Last Post: 09-13-2011, 12:58 PM
