603,308 active members*
3,144 visitors online*
IndustryArena Forum > CNC Electronics > SmoothStepper Motion Control > ESS connected to C85 breaker board/driver Homing problem
Results 1 to 8 of 8
    Apr 2003
    4
    I have an ESS Smooth Stepper connected to a C85 board. I am running Mach3 with Mechanical limit switches wired in. When I activate the limit switch for any axis, I see that corresponding input light up on the C85 board and on the Mach screen. I run that axis toward the switch and activate it manually but the motor does not stop.
    I can not figure out what is going on. I am not running the version of Mach3 that is suppose to have homing problems. Any help would be greatly appreciated.
    Jan 2018
    1516
    Re: ESS connected to C85 breaker board/driver Homing problem
    Have you assigned the correct pin number of the ess to the axis lilmit input?.
    The lights will light up saying it's working but if mach doesn't know where the switch is it will do nothing.
    Apr 2003
    4
    In Mach the pins I assigned are X Home-11, Y Home-12 and Z Home-13.
    Jan 2018
    1516
    Quote Originally Posted by stellartom View Post
    What about the port number?. Have you selected the correct one of those?.
    For instance. If Mach is set for say port 1 but you've plugged the IDC26 from the C85 into port 2 of the ess, Mach won't see it. Mach would need all the pins set as port 2 in the inputs.
    Apr 2003
    4
    Yes I am using Port 1 on the ESS board. What's making me scratch my head is the external E-Stop button is on pin 10 and it functions correctly.
    Apr 2003
    4
    Found my problem. Connection issue, all is well.
    Jan 2022
    Thanks for the article, a very good topic. slope
    Aug 2024
    It sounds like your limit switches are correctly wired and detected, but the motors aren't responding when they trigger. Double-check your Mach3 settings you can read more here. under Config > Ports and Pins > Input Signals to ensure the limit switches are assigned properly. Also, try adjusting the debounce setting in General Config to reduce noise issues. If the problem persists, consider creating a new Mach3 profile to rule out configuration issues. If everything seems correct, it might be worth contacting support for the ESS Smooth Stepper or C85 board.
  1. ESS MB3 Index homing
    By Jonatanw in forum SmoothStepper Motion Control
    Last Post: 12-30-2020, 10:35 PM
  2. Homing problem ESS
    By squirrel_41 in forum Mach Wizards, Macros, & Addons
    Last Post: 11-03-2019, 09:29 AM
  3. How to use all 8 Axes in Kflop Board Connected with Kanalog Board
    By amitkumar171 in forum Dynomotion/Kflop/Kanalog
    Last Post: 09-24-2018, 06:57 AM
  4. Replies: 1
    Last Post: 12-14-2016, 03:10 AM
  5. 24V supply leaps to 35V when driver board connected!
    By HankMcSpank in forum Stepper Motors / Drives
    Last Post: 08-26-2008, 10:27 PM
