Chinese 3 Flute endmill 100mm 40mm doc. Carbide. Really nice. I use them new for finishing and when new they shave alloy hairs into the air leaving a finish that makes a DIY proud.
Limited to DOC of 40mm or in the case of the smaller end mills I would like to waste a small section to avoid rubbing above the flutes.
How much? 0.5mm off the diameter for 15mm or so. I've thought about putting a grinder in the vice on my lathe to do it? But is there a proper or better way?
Sent from my SM-N970F using Tapatalk
