586,069 active members*
3,554 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > please, question about transfer cut
    Jun 2015
    4154
    hello after cut-off between spindles in G140, i change to G141 in order to machine on 2nd spindle
    during this sequence, 2nd spindle stops ( after transfer as slave for 1st spindle that stops ) then starts spining again under G141 mode
    please is it possible to stop only the 1st spindle, and keep revos on 2nd ? thus is it possible to use M150 without stoping s2, or is there a wayarround ? kindly
    Mar 2009
    1982
    Re: please, question about transfer cut
    you need turn off the spindle sinchronisation instantly after transfer.
    Apr 2009
    1262
    The Spindle will return to what it was doing before M151 was activated so if revolving before it will be revolving after. M151 can be activated either stopped or spinning.
    Does direction change when going into G141 vs cutoff?
    Experience is what you get just after you needed it.
    Jun 2015
    4154
    thank you mr wizard i thought that s2 has to be static before m151, i also thougt to trick it by making the transfer in g141 ?!
    but you are right, it can be also spining, and after m150 it will reverse to whatever was doing before; nice trick how did you find it ?
    it was the chery on top for my list related to dual spindles :
    ... static transfer, normal or with orientation
    ... cut of transfer, with protection for blade and detection if part is still in subspindle
    ... turning and milling a long part, being clamped in both chucks
    ... using 2nd spindle as tailstock
    ... keep s2 spining after transfer for continous machining, by avoiding useless stop
    please, is there something else ?
    yes, normally it does, or so far it was like that now, for some repetitive simple parts, thanks to you, is possible to use L hand tools / kindly
  1. Type3 4.3 transfer, Artcam Express 2012 transfer
    By frankleng in forum For Sale Only
    Last Post: 05-15-2014, 03:28 AM
  2. Lic transfer question
    By cncadmin in forum BobCad-Cam
    Last Post: 04-25-2013, 06:02 PM
  3. data transfer question
    By Lars1990 in forum Deckel / Dialog
    Last Post: 11-04-2011, 01:04 PM
  4. 2D cut out question
    By mortkork in forum CNC Tooling
    Last Post: 12-05-2009, 03:43 AM
  5. BobCAD software lic transfer question.
    By rustyolddo in forum BobCad-Cam
    Last Post: 07-22-2004, 04:44 PM
