586,121 active members*
3,005 visitors online*
    Feb 2007
    592
    Question Removing Spindle motor.
    Is there anything else besides the 4 bolts and the wiring holding the OEM motor to the machine?
    I mean to remove it am I going to have to pull off the top gearbox cover also?
    Jun 2005
    1015
    nope, just pull it off carefully its kinda heavy.
    Jun 2006
    2512
    Mine was a bit tight, which made me think something else besides the four bots was holding it. Trouble with just trying to lift by hand is you have to wiggle it back and forth in order to get it free for lifting. Then when you get it a little way up it skews over slightly and gets tight, so you wiggle it a bit more firmly and it drops back down again.
    I put some wedges under the motor flange while wiggling. If you have the possiblilty maintain some tension on the motor with a chain hoist while wiggling, it should come up easily.
    Hope you understand all the wiggling bits.
    Regards
    Phil
    Quote Originally Posted by skullworks View Post
    Feb 2007
    592
    Cool Thanks all for the replies.
    I did not want to apply any force until I was certain I was not fighting any other retention hardware.
    The plastic electronic box (on motor) seems to always be in the way and at risk no matter which method I use to hoist the machine. So I wanted the motor and wiring off. The side benefit is the reduced mass will make for less inertia issues and keep the weight at a lower C.G. while moving.
    Jul 2007
    75
    Simple Solution
    Hi Skullworks;
    If you haven't taken the motor off yet you may want to do as we do, just remove the 4 bolts and turn the motor 90 degrees counter clockwise. Put 1 bolt back to hold the motor in place, then procede to do what you are doing.
    IHCNC
    Gene & Tommy
  1. more rpms for spindle motor and spindle
    By bob1112 in forum Mechanical Calculations/Engineering Design
    Last Post: 02-10-2007, 08:01 PM
  2. Removing pulley from Taig spindle
    By warpedmephisto in forum Taig Mills / Lathes
    Last Post: 04-02-2006, 10:53 PM
  3. How to removing a pulley from a motor ??
    By RotorRouter in forum CNC Machine Related Electronics
    Last Post: 11-13-2005, 02:32 AM
  4. Removing the armature ?
    By Ken_Shea in forum Servo Drives
    Last Post: 10-10-2005, 08:40 PM
  5. Removing permanent magnet stator from the motor
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 04-11-2004, 08:57 PM
