586,036 active members*
3,578 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > .007" egg-shaped holes while circle-milling
Results 1 to 8 of 8
    Nov 2013
    402
    I'm getting about .007" egg-shaped holes while trying to circle mill.
    It appears to be happening in the X Axis.
    Does this sound like a backlash issue, and what needs adjusting?
    Dec 2013
    5717
    Re: .007" egg-shaped holes while circle-milling
    It does sound like a backlash issue. The normal causes are: 1) loose motor coupling, 2) thrust bearing adjustment, 3) worn ball nut/screw.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2018
    1516
    0.007" that's like 0.17 ish in mm. That's a lot for it to be a backlash problem alone.
    Sounds like something is loose or needs a lot of adjustment.
    Dec 2008
    3109
    Which axis has the correct size for the diameter ? .... that is the axis that doesn't have a problem.
    Are there flats where the axis changes direction ?
    As Daz says, check all items that are on that axis, I've seen bodgy work where some builder used pointed set screws instead of keys on drive mechanisms.
    Nov 2013
    402
    Y axis is correct, X axis is over-sized .007".
    I'm guessing it's the Thrust-Bearings.
    Not on a Tormach, but the last time I had an issue like this the ballnut was loose in the carriage. Easy fix.
    Dec 2009
    8
    Quote Originally Posted by RussMachine View Post
    Check the play between the ball nut halves in the X axis. They have a spacer between them to preload them. Put in enough shim to take out the slop.
    Jun 2014
    1780
    Quote Originally Posted by bfnt77 View Post
    I did this on my Y axis ball nut,it worked well. I am thinking offset keys that hold the two halves together, then a spacer shim wouldnt be needed, I just have to get up the "want to" to get it done.The parts I make arent that critical.
    mike sr
  1. .010" egg-shaped while circle milling.
    By RussMachine in forum Tormach Personal CNC Mill
    Last Post: 11-24-2020, 05:27 AM
  2. What insert can I use to make a small radius (0.004"-0.007") on a part
    By Liberty02 in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 08-16-2011, 03:58 PM
  3. Steel Ring Egg Shaped and Poor Finish
    By LaysMachinist in forum Material Machining Solutions
    Last Post: 03-01-2011, 07:32 PM
  4. Milling rectangular holes on a bolt circle
    By 69ss396 in forum Haas Mills
    Last Post: 04-16-2010, 10:54 PM
  5. Help with egg shaped circles
    By Trucks in forum DIY CNC Router Table Machines
    Last Post: 09-29-2009, 12:37 AM
