603,900 active members*
3,085 visitors online*
    May 2009
    136
    Question DMM Servo Tuning
    Hello All,
    I just recently got my DMM 750W Nema 34 servos mounted on my machine and ready for tuning, however, I'm not able to run the auto tune from the DMM software. The drive (Dyn4) faults out (overcurrent) on the High Frequency Sweep test, this happens very time, I have tried to adjust the servo settings lower but nothing makes a difference. Has anyone else ever experienced this issue or know what needs to be done so the auto tuning process can be completed?
    Mark
    Jan 2018
    1516
    Re: DMM Servo Tuning
    Shows this in the manual
    - Check that the encoder feedback cable
    is securely plugged from the servo motor
    to the JP3 port of the servo drive.
    - Check for any mechanical irregularities
    that might be preventing the motors to
    move freely
    Dec 2013
    5720
    Try these settings and see what happens
    2) Position Servo Mode
    3) High Load Inertia (I don't think we tried this one yesterday)
    4) Rigid Mechanism (I know we didn't try this one)
    5) Torque Filter = High
    If this works, then change one parameter and try it again.
    Rinse/Repeat
    The goal is to get it to tune with #2 set to Torque Servo Mode and #3 set to Belt Mechanism
    This is the only way I can think of to see what parameter it is failing on.
    Note to other readers, I spent an hour on the phone with Mark yesterday.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2010
    72
    Weird thing when I was tuning mine - out off 3 sets 1 would auto tune the other 2 would not. I swapped the drives over on the 2 that would not auto tune and they have worked great ever since - something you could try maybe?
  1. DMM Servo
    By seapacer2 in forum Dmm Technology
    Last Post: 06-27-2021, 08:46 PM
  2. DMM servo set up
    By wantacnc in forum Dmm Technology
    Last Post: 07-21-2020, 02:48 AM
  3. Replies: 44
    Last Post: 06-21-2019, 10:35 PM
  4. Tuning DMM Tech Servos/Drives
    By jsantos in forum Dmm Technology
    Last Post: 12-18-2014, 06:01 PM
  5. DMM 1000rpm 750w Servo - Low RPM for servo?
    By cncjunky2011 in forum Dmm Technology
    Last Post: 05-26-2012, 01:09 PM
