586,110 active members*
3,204 visitors online*
Results 1 to 8 of 8
    Oct 2006
    48
    EMC - Estop & Active high and low
    hi... i am struggling to get my estop configured properly...
    in the manual it says that the code to enable estop is..
    linkpp parport.0.pin-01-in iocontrol.0.emc-enable-in
    and the code to enable an active low is -invert
    i cant get my estop pin inverted, no matter where i place the -invert...
    please help
    Jul 2003
    1754
    I think you do this
    setp parport.0.pin-01-in-invert 1
    Quote Originally Posted by ADucci View Post
    please help
    Jul 2003
    1754
    btw - pin 1 on the printer port is not setup normallly as an input.. 10,11,12,13 and 15 are.
    sam
    Oct 2006
    48
    Thanks Samco.... this looks right... i will try it tonight...
    ps.. yes... this sample is from the help file... my estop is on pin 10...
    thanks a mill.
    Oct 2006
    48
    i can get emc to not give an error using that exact code you specified.. namely
    however, my Estop is on Pin10... when i change this code to pin 10, it gives an error...
    Jul 2003
    1754
    what is the exact errror?
    should be
    linkpp parport.0.pin-10-in iocontrol.0.emc-enable-in
    setp parport.0.pin-10-in-invert 1
    Jul 2003
    1754
    so - on the irc chat I found out I was wrong.
    Inputs have 2 pins already.
    parport.0.pin-10-in
    and
    parport.0.pin-10-in-not
    so the correct line is
    linkpp parport.0.pin-10-in-not iocontrol.0.emc-enable-in
    you don't need the setp line - as that is only for outputs.
    sorry about that. I assumed something I should not have
    Oct 2006
    48
    thanks, that worked perfectly!
  1. Active high vs. Active low
    By aaronkeit in forum Gecko Drives
    Last Post: 08-22-2007, 08:57 AM
  2. What does active Hi and Lo do?
    By phantomcow2 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-17-2005, 07:21 AM
  3. active Lo or active Hi?
    By phantomcow2 in forum Hobbycnc (Products)
    Last Post: 09-28-2005, 11:18 AM
  4. Active High/Active Low
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-07-2004, 03:47 AM
