603,308 active members*
3,264 visitors online*
IndustryArena Forum > Other Machines > Commercial Products / Manufacturers Support Forums > Automation Technology Products > 3 Axis EtherCAT NEMA 23 Motion Control System Working With Mach4 for CNC Machine
Results 1 to 1 of 1
    Testing 3 Axis EtherCAT NEMA 23 Motion Control System Working With Mach4 for CNC Machine -- EtherCAT Stepper Driver and Motors
    Product Link:
    https://www.automationtechnologiesin...tem-with-mach4
    Includes:
    -- 1pcs EtherCAT Motion Controller, Working with Mach4
    --3 Pcs NEMA 23 Stepper Motors (570 Oz-in) with 1.5 Meter Cable
    -- 3 Pcs EtherCAT Stepper Driver, EtherCAT Stepper Driver, EM3E-870E
    -- 1 Pcs 48VDc 12.5A Power Supply
    -- 3 Pcs Proximity Switch with 1.5 Meter Cable
    -- 1 Pcs E - Stop with 1.5 Meter Cable
    -- 1PCS 12Vdv Power Supply for the limit switch
    We can configure 4 Axis, 5 Axis, 6 Axis ..... to N axis
    We can change from 1.5-meter cable to other Length as you need
    Attached Thumbnails Attached Thumbnails EtherCAT-Kits-Wiring-Diagram-1024x1024.jpg
  1. Running DDCS CNC Motion Control System with MPG, NEMA 23 Stepper Motor
    By automationtechinc in forum Automation Technology Products
    Last Post: 08-27-2021, 09:46 PM
  2. DDCS Motion Control System with MPG, Testing with NEMA 34 Stepper Motor
    Last Post: 08-18-2021, 10:03 PM
  3. 3 Axis EtherCAT NEMA 23 CNC Motion Control System with Mach4
    Last Post: 06-22-2021, 03:09 PM
  4. Mach4 EtherCAT System
    Last Post: 09-12-2020, 05:49 AM
  5. Replies: 0
    Last Post: 12-17-2013, 01:14 AM
