603,946 active members*
2,033 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Post processor editing
Hybrid View
kenwoodhf Post processor editing 01-20-2022, 08:15 PM
andre-dolphin Re: Post processor editing 01-30-2022, 11:55 AM
HighSideNZ Re: Post processor editing 10-09-2023, 12:27 AM
andre-dolphin Re: Post processor editing 10-09-2023, 11:02 AM
HighSideNZ Re: Post processor editing 10-10-2023, 11:01 AM
    Mar 2013
    11
    I am using the post processor for EMC-2. Is there a way to put a space after the line number in the G code. It would be allot easier to read it. I have tried to change things in the file but have had no success. Thanks Jan
    Feb 2007
    417
    Hello
    You can introduce a space character after the block number macro #N
    So where you see #N add " " (there is space character between the quotes) to read #N " "
    You will need to do this on each lines that contains the #N in the RULES section of the post
    ATb
    andre
    Aug 2021
    34
    HI
    Carrying on from this post, can you add a space between program content like the following?
    N11 G99G83X183.0Y41.0Z-14.667Q2.933R3.0F200
    make it like
    N11 G99 G83 X183.0 Y41.0 Z-14.667 Q2.933 R3.0 F200
    Phil
    Feb 2007
    417
    Hello Phil,
    Yes, you need to add an underscore character before each word ..... this is the groups section from a fanuc lathe post ....
    GROUPS:
    :G1 = { _G00 _G01 _G02 _G03 _G33 _G77 _G78 _G79 _G92 }
    :G2 = { _G96 _G97 }
    :G3 = { _G90 _G91 }
    :G4 = { _G94 _G95 }
    :G6 = { _G20 _G21 }
    :G7 = { _G40 _G41 _G42 }
    :M1 = { _M03 _M04 _M05 }
    :M2 = { _M08 _M09 }
    :M3 = { _M33 _M34 _M35 }
    :M4 = { _M78 _M79 }
    END:
    Then use this in the MACRO and RULES sections ....... examples below
    #CRC = { [CUTCOM ? (_G40) / (_G41) / (_G42) ] }
    :GOCLW = { #N (_G02) #CRC #Y #X #I #J #F EOB }
    ATb
    Andre
    Aug 2021
    34
    Thanks Andre
    Worked like a charm.
    I feel it is much easier to read like this.
    N10 G94
    N12 G80
    N13 M09
    N14 G49
    N15 T4 M06 ( Ball Nosed End Mill 10mm Dia )
    N16 G00 G43 Z50.0 H0
    N17 S700 M03
    N18 G94
    N19 X60.0 Y51.624
    N20 Z3.0
    N21 G01 Z-1.0 F100
    N22 X60.0 Y30.376 F200
    N23 X166.0 Y37.829
    N24 X166.0 Y44.171
    N25 X60.0 Y51.624
    N26 X64.5 Y46.796
    Cheers
    Phil
  1. Editing post processor
    By SuperUPer in forum EnRoute
    Last Post: 08-16-2018, 09:16 PM
  2. Post Processor Editing
    By ErickH in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-24-2015, 07:58 PM
  3. POST PROCESSOR EDITING
    By blmmdes in forum Hypermill
    Last Post: 05-08-2008, 06:27 PM
  4. Post Processor editing
    By CNC_savant in forum MetalWork Discussion
    Last Post: 04-03-2007, 01:45 AM
