586,108 active members*
3,069 visitors online*
Results 1 to 7 of 7
    Feb 2022
    I/O port pinout on Taig/Microproto
    Hello all. I have a Microproto 2000 HD/LE that I am running with Mach3. I want to add an E-stop and possibly limit switches. Does anybody have a wiring diagram or pinout for the I/O port on the rear panel? I need to be able to connect to one of the input pins on the DB25 that Mach3 uses. Thanks very much.
    Apr 2013
    Re: I/O port pinout on Taig/Microproto
    Did you find the pinouts? I am going down the same path. TIA
    Jun 2022
    4
    Any updates on this? I'm in a similar position; haven't had any luck in finding these pinouts!
    Jun 2022
    4
    Just posting this here for others, but I found someone who had a physical copy of the manual for the MicroProto. I was able to get them to send me images of the I/O port documentation:
    Attached Thumbnails Attached Thumbnails 93231631_10222797251740247_3250387818903502848_n.jpg
    Jun 2022
    4
    Forgot to add these ones as well, which shows which connection is which on the parallel port. The first image has all the pin mappings excluding the 4th axis and emergency stop. The second image shows that the emergency stop is on pin 10 of the parallel port.
    Attached Thumbnails Attached Thumbnails 94261895_10222797260100456_822311861511782400_n.jpg   microproto-pinout.gif   94261895_10222797260100456_822311861511782400_n.jpg
    Jun 2022
    4
    Apologies for all the replies, I keep forgetting to add important bits of info. This should be the last of it though.
    The 3 limit and 1 EMO/Estop inputs (pins 1-4 on the DIN, and 5 if you want the 4th axis limit) should all be directly shorted to GND (pin 8). No need for a current limiting resistor or anything. In my case using LinuxCNC, I had to set these as the "Maximum <X,Y,Z> + Homing", and then invert the input.
    I'm unfamiliar with Mach3/4 and if you can change if it reads high or low as reaching the limit, but factor this into your design when deciding between NO or NC switches. From my reading, I would also recommend isolating the switches (e.g. using relays or optocouplers), and using a higher voltage (e.g. 24V)/shielded wires to deal with noise and prevent false limit signals.
    Great intel!
    I'd like to hook up an AC servo driver, AASD 15A, to replace de original spindle motor. how can wire the DIN8 I/O port of the microproto controller to the female DB25 I/O port of the servo driver?
    link to the Servo driver and the Pinout for the db25 CN2 port that I'd like to link to the microproto controller: https://docplayer.net/124061226-Aasd...jL5pmw4NAO3uyk
    thanks in advance
  1. Any interest in a Microproto (Taig) 2000 Machine?
    By abeship in forum Taig Mills / Lathes
    Last Post: 08-16-2016, 07:50 PM
  2. Replies: 14
    Last Post: 09-19-2015, 10:45 PM
  3. taig microproto 2019-ER mach 3 configuration
    By pepperwood in forum Taig Mills / Lathes
    Last Post: 08-12-2012, 03:44 AM
  4. Taig/MicroProto problem
    By Sweeney in forum Taig Mills / Lathes
    Last Post: 08-19-2010, 10:46 PM
  5. MicroProto Taig Mill
    By vayacon in forum Taig Mills / Lathes
    Last Post: 10-14-2004, 09:58 PM
