586,096 active members*
3,683 visitors online*
    Step/Dir Spindle runs SLOW
    I'm trying to set up hybrid motor for my spindle on a small lathe. I think I have the wiring correct. M3 and M4 turn the motor forward and reverse.
    At present, the motor is not actually driving the spindle so I have de-activated the index.
    But I can't get any real speed out of it. The motor has a default value of 4000 steps per revolution. I changed that to 1600 s/r.
    With a value of S400 I only get 31.5 rpm. With S3000 I get 46.0 rpm. Hardly linear.
    If I lie to Mach3 and set the s/r to 16,000, the rpm's increase to a predictable 315 rpm and 462 rpm.
    I have to think it's something in my setup but I'm out of ideas and hoping someone here has something for me.
    Re: Step/Dir Spindle runs SLOW
    Update:
    Last night I disconnected the new hybrid motor, dug out an old G201 and an even older Pacific Scientific stepper and hooked that up. Same slow result.
    This morning I changed those outputs from spindle to 'Y' axis. (Should have thought of that in the first place). The motor acted normally.
    So, the issue is defiantly with the step/dir spindle function in Mach3.
    Has anyone gotten a step/direction spindle to work? What version of Mach3 were you using? I'm using 3.042.029.
  1. Fanuc 6M runs spindle very slow
    By mzoner in forum Fanuc
    Last Post: 06-09-2021, 04:25 PM
  2. WIXHC MK6-V Motion card on Mach3 STEP/DIR Spindle control
    By quickjam in forum Controller Cards
    Last Post: 08-08-2019, 03:29 PM
  3. KFlop to step/dir spindle
    By macona in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-14-2017, 09:06 AM
  4. KFlop how to configure spindle as Step and Dir No output for DIR
    By vetsen in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-08-2015, 07:08 PM
  5. Problems with spindle control via step/dir
    By glentner in forum Machines running Mach Software
    Last Post: 08-19-2012, 04:53 PM
