586,119 active members*
3,585 visitors online*
    Jan 2016
    6
    Wiring a Laser to my CNC using an External 12V Power Supply
    Hi all... I've bought a laser to attach to my already operational CNC mill... As usual with Chinese parts the documentation is useless and doesn't cover any wiring info - leading me to search it out instead. Except I can't find exactly what I'm looking for - can someone confirm whether I have understood things right?
    I have a DB25-1205 breakout board. It has a 5v power supply only - not a 12v supply like my laser needs, neither does it have a relay. You can see it here:
    My Laser is a Sculpfun S9. It has a 3 pin connection on the controller board already that's mounted to it. The pins are '(12V+' 'GND' 'PWM')
    https://www.sculpfun3d.com/productinfo/720040.html
    Is my solution to simply connect both wires from a 12v power supply to the Vcc and GND pins above - then connect a single wire to the PWM pin and run that to one of the pins (pin 17 I understand) on my breakout board?
    If that is correct then I guess I can power on the laser by turning on the power supply - but it will be effectively off until the software sends a PWM signal to fire it up?... i.e by me running code or playing with the controls manually in Mach3
    I hope this makes sense... All advice appreciated ????
    Jan 2016
    6
    Re: Wiring a Laser to my CNC using an External 12V Power Supply
    OK so I have done a bit more research and think I was close but also need to run a wire from -12v GND on the laser back to GND on my BOB..... here is a basic sketch as I think it needs to be... is this right??
    Basically I'm concerned about connecting -12v to the GND on my BOB because everything else on it is -5V but I heard that a common GND is fine regardless and it's ok to mix-12v and -5v.
    Mar 2011
    Quote Originally Posted by dcrowder79 View Post
    Did it work?
    Jun 2005
    1730
    Your drawing looks correct that should work
  1. LC6090 Wiring into Laser Power Supply
    By fdiv_bug in forum G.Weike Laser
    Last Post: 04-27-2021, 09:43 AM
  2. 12v power supply
    By jim_cliff11 in forum CNC Machine Related Electronics
    Last Post: 01-23-2017, 04:25 AM
  3. Need help diagnosing a laser power supply wiring
    By coreman in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 12-13-2015, 09:53 PM
  4. Replies: 0
    Last Post: 04-19-2014, 12:43 PM
  5. laser power supply wiring help
    By Ed Williams in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-18-2010, 02:26 AM
