603,359 active members*
4,691 visitors online*
    Durma HDFL 3015 2kw Cutting issues
    Hi guys,
    Looking for someone to help me out on some cutting issues on or Durma Fiber Laser. Having lots of issues with nitrogen cutting for a start. I am using 15 bar for 14 gauge material with a 2 mm nozzle and still some burrs on the oposite side. I have been talking with diffrent laser opperators and they told me I shoudn't need over 10 bar pressure for that material. Feedrate 300ipm. Focus -0.07". Precitec Laser Head with 7.5 inch focal length also tried the 5 focal length in machine. IPG resonator 2kw. Nozzle gap at 0.012.
    Aug 2024
    Re: Durma HDFL 3015 2kw Cutting issues
    If you are using nitrogen or air for cutting carbon steel this pressure is not high and it is barely sufficient for a 2kw machine. To decrease the burrs you need to adjust the cutting spead and focus and do trial and error but generally lower spead and foccus help. Regarding the nozzle, maybe try a 1.2 mm double layer composite instead.
  1. Basic Model 3015 Fiber Laser Cutting Machine
    By liam_pitt in forum News Announcements
    Last Post: 03-05-2021, 04:59 AM
  2. Bystronic 3015: Parameters for Cutting Aluminum
    By AceLaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-28-2020, 05:29 AM
  3. Cutting compressed air Bystronic 3015
    By admin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-07-2019, 10:46 AM
  4. METAL LASER CUTTING MACHINE, MITSUBISHI ML 3015 LXP QUESTIONS
    By Sammy777 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-03-2019, 04:35 PM
