587,345 active members*
3,877 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC 3M Drip Feed Conversion Chip Transfer
Results 1 to 10 of 10
    May 2016
    25
    Hello All,
    I'm doing research at the moment, but believe that our main/motherboard in our mill, FANUC 3M-C, may have been damaged by a short circuit. It has the fanuc3mdripfeed.com chips on it. Does anyone know if I have to replace the board, can I simply transfer the chips to the new board? Or are the chips specific to an individual board or machine? Are there other chips or components that must be transplanted too? The board is a A16B-1000-0010 / 07f
    Thank you for your help.
    Aug 2009
    1573
    Re: FANUC 3M Drip Feed Conversion Chip Transfer
    ... they have you now.
    Aug 2008
    13
    you can simply transfer the Dripfeed chips what we call the system eproms to your new master pcb(A16B-1000-0010 ).do ensure that the small links/jumpers are kept as the original master pcb(A16B-1000-0010 ).
    May 2016
    25
    Quote Originally Posted by cnc.techie View Post
    Thank you cnc.techie. I appreciate your response. Second Question: I see the A16B-1000-0010 board ending with 07f, in my case. I am guessing that this is a revision level for the board. Would a board ending in 08f or 09f work? Ideally I would prefer to match everything exactly, but we don’t always get what we want.
    Thank you again.
    Dec 2009
    969
    yes it will work
    what is written after the ""/"" does not matter,indeed revision of the repair
    Aug 2008
    13
    Yes you can simply ignore what is written after the /
    Thnks
    May 2016
    25
    Thank you zavateandu
    Dec 2015
    41
    Transfer all the chips that plug into sockets. I just did this on my 3m not long ago. You may have to do the procedure to reactivate your drip feed chips again.
    May 2016
    25
    Thank you camaro_dan67.
    May 2016
    25
    Thank you all again for your input. I thought some of you might want to know the final outcome. With the help of a friend, we were able to trace the problem to the RS232 receiver chip on the main board. We desoldered it and replaced it with a new one. Today I was able to upload a program.
  1. Drip feed on a fanuc O-M
    By Jmorris in forum Fanuc
    Last Post: 08-13-2013, 02:34 PM
  2. Fanuc OM Drip Feed
    By danSN in forum Fanuc
    Last Post: 01-03-2012, 03:45 AM
  3. Drip feed for Fanuc 0-MF
    By giorgis in forum Fanuc
    Last Post: 05-08-2009, 04:44 PM
  4. Blockwise transfer,drip feed on Tnc 2500.
    By Paul cs in forum Bridgeport / Hardinge Mills
    Last Post: 09-02-2008, 02:45 PM
