603,898 active members*
2,714 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Hyundai SKT21 LMS Lathe Q Setter enable
Results 1 to 12 of 12
    Dec 2019
    17
    Hello, I recently purchased a 2006 Hyundai lathe with a Q setter, Fanuc controlled. The previous shop never used setters so apparently it's be disabled. I assume this is done through a parameter setting, but I've had zero luck figuring out how to turn it back on. Any help would be greatly appreciated!
    Apr 2009
    1273
    Re: Hyundai SKT21 LMS Lathe Q Setter enable
    It should be done through your keep relays. Which model of lathe do you have? They have different layouts for each model.
    Experience is what you get just after you needed it.
    Dec 2019
    17
    Interesting. It's a 2006 SKT21-LMS
    Apr 2009
    1273
    This should help you out. I think you're after D7.7 in your case.
    Best regards,
    Please let me know how it goes!
    Dec 2019
    17
    What is D7.7?
    Apr 2009
    1273
    It is a system data bit setting. Should be located in same area as keep relays under system button.
    Dec 2019
    17
    Thanks, I will search that out when I get to the shop.
    Dec 2019
    17
    It looks like the Data sheet you posted might be for a newer controller. Mine says "Fanuc i Series" and the data bits aren't matching up to what you posted. Dan
    Apr 2009
    1273
    Well, they do have a different version, but I'm not so sure it will work for your machine. Here is a copy for your reference:
    Best regards,
    Dec 2019
    17
    Those settings match what I have. I've gone in and changed D8.1 to 1. Is there anything else beyond that I should look for?
    Dec 2019
    17
    This is the alarm I get when I press the Auto Q-Setter button. The light on the proximity sensor turns on and off when I manually move the setter up and down, so I assume the sensor is good.... Not sure what could be going on.
    Quote Originally Posted by OkumaWiz View Post
    Best regards,
    Do you have any more parameters maybe D16 to the end of all the parameters? I have a sub spindle that got turned off and we are trying to get it running again.
  1. Replies: 10
    Last Post: 07-02-2025, 01:43 AM
  2. Replies: 2
    Last Post: 09-06-2023, 09:39 PM
  3. Hyundai Kia SKT20 LMS fanuc 0i
    By positiverake in forum Hyundai Kia
    Last Post: 01-23-2018, 11:34 AM
  4. Hyundai tool setter calibration
    By Dr Evil in forum Hyundai Kia
    Last Post: 04-25-2011, 10:46 PM
  5. fanuc oi-tc on a hyundai-kia skt21
    By mekdad in forum Fanuc
    Last Post: 12-11-2007, 01:01 AM
