588,199 active members*
4,886 visitors online*
    Oct 2008
    2105
    Broken Arbor Cap
    This slitting saw arbor cap broke. I was a little surprised. I put it in a drawer with a saw on it since I was going to use it again in a minute. The saw bound slightly closing the drawer, but I didn't force it. I shifted it so it wouldn't bind and closed the drawer. When I opened the drawer a few minutes later it took a moment for my brain to register what I was seeing.
    I left it for a few days, but I did notice right away that black staining that clearly shows a defect. Rust I could understand. This has run with flood coolant. Oily I could understand. I have used the arbor with cutting oil. The defect is clearly (in person anyway) dry and black. Finally it occurred to me that whatever they used to blacken the tool holder when it was new likely soaked into the defect then. I haven't used it much, but I'm sure its out of warranty. I guess I will be making a new cap for the tool holder soon. Thank goodness I have a lathe.
    Bob La Londe
    http://www.YumaBassMan.com
    Nov 2013
    402
    Re: Broken Arbor Cap
    Possibly cracked during heat-treating, or just flawed steel would be my guess.
    If it's a TORMACH toolholder, they may replace it for free.
    My first TORMACH 5" vise totally cracked and blew-out along the fixed-jaw keyway area.
    I sent it in for them to look at, and they gave me a free replacement.
    Oct 2008
    2105
    I sent them a couple pictures. They said it was out of warranty, but it never should have failed like that. They sent me a replacement for free. It arrived yesterday.
    Bob La Londe
  1. Arbor
    By Collins in forum Want To Buy...Need help!
    Last Post: 02-01-2012, 01:43 PM
  2. Need help going from Fanuc yellow cap to red cap
    By vsmi in forum Uncategorised MetalWorking Machines
    Last Post: 06-22-2010, 02:30 PM
  3. What Can You Do With A Arbor Press?
    By captainlee in forum Mini Lathe
    Last Post: 03-04-2008, 12:08 AM
  4. fit of an R8 arbor
    By wrenchcruncher in forum MetalWork Discussion
    Last Post: 11-19-2007, 07:51 PM
  5. Saw Arbor- where and what is this?
    By itwanabe in forum MetalWork Discussion
    Last Post: 08-09-2007, 04:14 AM
