587,478 active members*
3,125 visitors online*
    May 2003
    233
    spindle encoder
    i just started using emc2(its a little hard to set up but when done works great) on my mill now i want to try it on my lathe i use turbocnc now with a 1ppr encoder on the spindle for threading can i use the same setup with emc2 or do i need more pprs thanks
    Aug 2007
    7
    Lathe spindle encoder
    You need more than one ppr. This has been discussed a lot on the emc-users mailing list; here is one post I found about it: http://article.gmane.org/gmane.linux...emc.user/2575/
  1. Spindle Encoder to Mesa 5i20
    By RogerN in forum LinuxCNC (formerly EMC2)
    Last Post: 10-17-2008, 01:55 PM
  2. QT-28N spindle motor control encoder problem
    By Fred Raud in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-10-2007, 11:28 PM
  3. How do I orient spindle after encoder replacement? Torq Cut 22
    By vettespeed in forum Bridgeport / Hardinge Mills
    Last Post: 01-22-2007, 08:39 PM
  4. Spindle speed controler and encoder
    By Parameter in forum Mach Software (ArtSoft software)
    Last Post: 12-11-2005, 01:30 AM
