603,940 active members*
2,166 visitors online*
IndustryArena Forum > CNC Electronics > Dmm Technology > DYN2 TTL Communication
Results 1 to 8 of 8
    Oct 2014
    Question DYN2 TTL Communication
    Hello, has anybody had any luck connecting to a DYN2 drive with a non-DMM USB to TTL cable?
    My genuine DMM communication cable is broken, and the non-DMM converters are much cheaper.
    I have purchased one of these, but haven't had any luck connecting through DMM servo software. https://core-electronics.com.au/usb-...-pl2303hx.html
    If someone has had luck getting this to work, or knows of what settings are required in windows device manager, that would be much appreciated!
    15362
    Re: DYN2 TTL Communication
    Quote Originally Posted by calmorey View Post
    How old are your drives as this cable changed??
    Can you do a photo of what your original cable is, the older cables are custom and there is nothing you can buy from someone else that will work
    Mactec54
    Oct 2014
    The drive is a DYN2-TLA6S-00, bought in 2017. The cable serial number is:
    CA-MTUSB-FR1
    ED-1 0117A
    AC2 82901
    15362
    CA-MTUSB-FR1
    ED-1 0117A
    AC2 82901
    The cable you have should work but you would need the plug for the drive to be wired correct, you can get a new cable from DMM or try and make the one you have work here is a video on how to use the cable once you have a com port connection
    https://www.youtube.com/watch?v=WNzTOfGnG50
    Mactec54
    15362
    CA-MTUSB-FR1
    ED-1 0117A
    AC2 82901
    I said that cable should work, it may not match the converter that DMM is using in their cable that is why their cable costs more, the converter will be to suit their drive commutation so is a custom made cable
    Mactec54
    Jan 2023
    I have purchased one of these, but haven't had any luck connecting through DMM servo software. gb whatsapp
    Did you tried cable connectors?
    Jan 2023
    I have purchased one of these, but haven't had any luck connecting through DMM servo software. https://core-electronics.com.au/usb-...-pl2303hx.html/fireboy and watergirl
    Can you provide a picture of your original cable? Older cables are bespoke and cannot be replaced.
    May 2023
    Haven't had luck with it either. Any advice greatly appreciated. Need for my fence
  1. DYN2 drive issues
    By Travis1581 in forum Dmm Technology
    Last Post: 04-14-2023, 06:58 PM
  2. Wiring up a Dyn2 drive, pr. DMM's schematics
    By EddySPalm in forum Dmm Technology
    Last Post: 04-14-2023, 06:46 PM
  3. taig/dmm/dyn2/acorn settings
    By Grascochon in forum Taig Mills / Lathes
    Last Post: 04-01-2020, 03:52 AM
  4. Dyn2 losing EEPROM settings
    By matth in forum Dmm Technology
    Last Post: 02-18-2020, 04:32 PM
