586,110 active members*
3,354 visitors online*
IndustryArena Forum > MetalWorking Machines > Auto Tool Changer > Using BT40 Without Drive Lugs
    Oct 2009
    84
    I have a 5 HP, 8000rpm spindle in my BT40 machine. I currently don't have my spindle orientation working yet. What do you think about light machining without the drive lugs so that I can use my toolchanger until I get the spindle orientation working?
    Re: Using BT40 Without Drive Lugs
    there isn't much other than a very slight amount of friction to prevent the holder from slipping in the taper , not worth the risk in my opinion .
    It's probably best to focus on getting your orientation corrected before running any cuts , or hand bomb your tools until you get things running properly
    Aug 2016
    132
    Will it work? Sure. Plenty of 30 taper machines don't have drive dogs and HSK without drive dogs goes up to 63, I think.
    How light of a cut you need to take to not spin the tool no one can answer for you, though.
    Aug 2009
    1573
    Quote Originally Posted by jlmccuan View Post
    ...No problem running keyless with light to medium machining. I have seen many machine 40 taper without the Keys.
    If, you would like some help figuring out why the machine Spindle Orient (M19) doesnt work..give us Make Model cnc you have 1st and want the machine is doing or not doing.
    DJ
    Oct 2009
    84
    The spindle orientation not working is because I'm using a VFD and need to add a position indicator. I already have a profile set up in the VFD to run reversed at 30 rpm for tool height and diameter probing as well as hopefully spindle orientation once I get it installed.
  1. Simple question on those cheap belt drive BT40 spindles
    By Greg9504 in forum Spindles / VFD
    Last Post: 05-20-2022, 09:38 PM
  2. BT30 or BT40 ?
    By kimhan in forum MetalWork Discussion
    Last Post: 11-04-2019, 12:18 PM
  3. lugs on spindle ???
    By LEARN in forum Charter Oak Automation Support Forum
    Last Post: 01-16-2015, 02:05 PM
  4. Whats missing? Drive lugs
    By Jet A in forum Bridgeport / Hardinge Mills
    Last Post: 11-09-2011, 10:42 PM
  5. Hydraulic crimping of cable lugs..
    By hotponyshoes in forum CNC Machine Related Electronics
    Last Post: 02-27-2008, 04:00 PM
