586,121 active members*
3,637 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > rapid acceleration for a short time.
    Mar 2021
    hello
    I need rapid acceleration for a short time.
    Every 62.5 ms, the acceleration should be switched between forward and reverse directions.
    Also, the required instantaneous RPM is 400 RPM.
    In other words, every 62.5 ms, you need to switch 400 RPM forward and 400 RPM reverse.
    Is it a viable story if the capacity is sufficient?
    The inertia of the load can be reduced to test it.
    If you think it is possible, please recommend a product.
    Nov 2013
    4376
    Re: rapid acceleration for a short time.
    the second of Newtons laws is 'force equals the time rate of change of momentum.'
    If you wish to reverse the momentum of an object instantaneously that would require infinite force, which is clearly impossible.
    The better way to describe the problem is that for a given momentum what force (force being analogous to torque) is required to reverse the momentum
    in a given time. Then the only question is how much elapsed time is considered good enough for your application.
    If you were to detail things like the momentum, ie mass and speed of the object to be reversed, the mechanical means of converting motor torque to
    linear acceleration, say ballscrew, or rack and pinion we might be able to do some calculations that would tell you whether its possible or more prehaps feasible at a cost.
    Craig
    15362
    Quote Originally Posted by kimwoo0 View Post
    hello
    AC servos can do this, you have the problem of how much torque the motor will need to overcome the inertia, so you have to know what the inertia will be and then get an AC Servo motor that can handle the inertia, here is a good video of the DMM AC servos in action with different inertia loads
    https://www.youtube.com/watch?v=fyKBKUkFJVA&t=9s
    Mactec54
    Dec 2021
    31
    We produce DRO and linear scale, maybe it will help you, you can go to https://www.amazon.com/stores/HHXXOV...2?ref_=ast_bln
    view on
    Or on Whats: +8613528773691
    Contact me at [email protected], [email protected]
  1. Replies: 1
    Last Post: 01-13-2021, 08:18 PM
  2. Replies: 3
    Last Post: 04-27-2015, 04:09 PM
  3. Running short on time...
    By SSLLC in forum PlasmaCam
    Last Post: 05-08-2014, 12:06 AM
  4. Time logging of position, velocity and acceleration
    By maxlem in forum Mach Software (ArtSoft software)
    Last Post: 04-15-2009, 02:15 PM
  5. Replies: 0
    Last Post: 07-31-2008, 10:35 AM
