586,104 active members*
3,510 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Programming backside sphere on Okuma
    Hello, I am trying to program the backside of a sphere with a cutoff tool on an Okuma Crown using the igf. If I use OD it wants to cut along the Z axis, and if I use the OD face it wants to make the arc inverted. I would like it to do some sort of LAP cycle so it rough grooves the sphere, then takes a pass on an arc to finish the sphere. Does anyone know how to program this is IGF without having to program each groove individually? TIA
    Jun 2015
    4154
    Re: Programming backside sphere on Okuma
    hy jacob on newer igf, is possible to use od groove operation ( rough or finish ), that works with both offsets, thus both cutting edges of the cutoff tool ( thus p3 and p4 rad comp quads )
    the tricky part, is that the shape should not begin, nor end with an arch, so direct aproach will fail; one way to fix it, is to add imaginary lines
    on the other side, i have a custom code for cutt-off, that can handle corner chamfer or corner radius, and it handles it in one-shot, or by multiple passes : for example, i few days ago i delivered some o30 parts, with 5mm radius at the far end, and the cut-off tool is roughing those 5mm with multiple passes at 0.6mm doc, then finishes it; if you wish, i'll just share it / kindly
  1. Drilling aluminum plate causing bubbles on backside
    By TheHiggsBroson in forum MetalWork Discussion
    Last Post: 05-27-2017, 04:16 AM
  2. Replies: 0
    Last Post: 01-31-2017, 01:58 PM
  3. Vulcan 2900 backside cable wiring
    By JL-WSHVAC in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 06-01-2015, 03:19 PM
  4. Replies: 4
    Last Post: 10-02-2014, 04:58 AM
  5. Okuma Programming
    By Seva in forum Okuma
    Last Post: 04-27-2011, 04:55 AM
