603,960 active members*
3,449 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Windows Administrator password
Results 1 to 6 of 6
Hybrid View
J_Vision Windows Administrator password 08-08-2022, 08:47 AM
Dec0y Re: Windows Administrator... 08-14-2022, 09:52 PM
mill_about_smartly Re: Windows Administrator... 02-04-2025, 06:54 PM
tomgaasenbeek Re: Windows Administrator... 11-11-2022, 04:12 AM
MarcM Hatte heut genau das gleiche... 08-05-2024, 11:33 PM
RaderSidetrack Re: Windows Administrator... 08-06-2024, 02:30 AM
    Aug 2022
    Exclamation Windows Administrator password
    I was setting up the machine (Hurco VMX64i) on to the network following a step by step guide at one point windows had to be restarted to apply some setttings and now its asking for a Windows administrator password so now I cant open Winmax.
    Has anyone else run into this problem and if so how did they fix it?
    Apr 2020
    52
    Re: Windows Administrator password
    google herens boot cd password recovery
    Dec0y, thank you for posting this! My service rep lost their contract with Hurco a few years ago and I was going to have to pay for a tech to drive 8 hours 1 way to solve this dumb Windows problem. With your suggestion I was able to make a boot drive on a USB, start the mill off the USB, and erase the admin password on the original partian. Everything works like normal now.
    Your post probably saved me $4,000-$5,000 or more plus a few weeks of down time. I literally created my profile so say "thank you" to you.
    A little more info for other people who might see this in the future. I've had my VM10Ui for about 6 years. I have it networked to my computer via a mapped drive... it just shows as the "H" drive from my desktop. I've never had an issue and never setup an administrator password on the mill. Yesterday I posted a program like I always do and I got a Windows notification saying I needed administrator approval because I didn't have access to that network location(or something to that effect).
    I don't know why it happened but my best theory is that there was probably a bad data packet when I tried to post that program and Windows on the mill saw it as a security threat because it didn't recognize my computer... I'm guessing this is the default response.
    Apr 2008
    13
    Hurco's zip code backwards - 86264
    Hatte heut genau das gleiche unglückliche Problem, selber verursacht. Befolgte ein tutorial von hurco zum einrichten des Netzwerkes und nach restart, den Login screen mit user:Administrator und ein leeres passwort Feld. Nach einigen Versuchen war das passwort "hurco" die Erlösung.
    Hoffe es wird vielleicht den ein oder anderen geben, der hiermit auch die richtige Lösung findet.
    Apr 2018
    159
    Here is how Google Translate does translating post #4 above from German to English:
    Had exactly the same unfortunate problem today, caused by myself. I followed a tutorial from hurco to set up the network and after restarting, the login screen with user:Administrator and an empty password field. After a few attempts, the password "hurco" was the solution.
    Hope there will be someone out there who will find the right solution with this.
  1. CNC Programmer/Administrator Needed NW Ohio
    By GLaukhuf in forum Employment Opportunity
    Last Post: 02-19-2021, 01:31 PM
  2. Subcontract Administrator 2
    By CSS Staffing in forum Employment Opportunity
    Last Post: 02-19-2014, 06:47 PM
