603,314 active members*
2,440 visitors online*
    Aug 2021
    Lightbulb GR200E coolant enable issue
    I have a lathe, with Philips 432T controller, 3511.500 software version.
    When I bought it, there were no machine parameters. Since then I make the parameter list, although it is not guaranteed perfect. Apart from the cooling function, everything works flawlessly.
    The keyboard good on internal test, and i also run g7-g8-g9 command in MDI-mode.
    I also tried with a rotating spindle, but the (turret) cooling does not turn on.
    I tried the electrical parts, the relay board and the contactor also good. When i push the contactor, the pump works well.
    I looked the outputs monitor mode, but the output card 1 : bit 16 wont enable when i push the cooland button or run m7-m8 command.
    Can someone help me with the conditions (possibly if a machine parameter) for turning on the cooling water?
    thanks for the help!
    Aug 2021
    Re: GR200E coolant enable issue
    Screenshot:
  1. MAHO GRAZIANO GR200E
    By AS3000 in forum SERVICE FOR CNC-MACHINES
    Last Post: 08-23-2021, 10:17 PM
  2. Coolant Issue
    By amish_rabbi in forum Novakon
    Last Post: 12-07-2014, 02:01 AM
  3. EZ PATH II coolant issue
    By jaredsparks in forum Bridgeport / Romi Lathes
    Last Post: 03-20-2012, 02:18 AM
  4. Need Help with Coolant Issue!
    By Chaps in forum MetalWork Discussion
    Last Post: 03-22-2010, 03:34 PM
  5. DX 32 coolant enable G code problem
    By Ranchero50 in forum Bridgeport / Hardinge Mills
    Last Post: 03-25-2008, 03:18 AM
