586,103 active members*
3,489 visitors online*
    Mar 2018
    4
    Using a Q value as defined by a Q-Value
    Hi All,
    I'm going to attempt to explain this as best I can.
    I'm looking for a way to use a value calculated from formulas as a Q number.
    For example if
    --Formula in here--
    Q1 = +100
    I would like the value calculated (+100) to be the next Q# (IE . Q100).
    How to I transfer the value calculated to be used as the Q number?
    Make any sense?
    Any ideas?
    I'm still working on it from my end, if I solve it I will post the answer/work around
    Cheers in advance
    Sam
    Mar 2018
    4
    Re: Using a Q value as defined by a Q-Value
    Update,
    After trawling the manuals and talking to a technical as Klartext, it would seem i am seeking the impossible.
    I'm going to go with using tables to input and output the data/numbers I need. FN26,27,28.
    Thanks for your input!
    I'll be back!!
    Sam
  1. Dual defined servo
    By tpsimer in forum Servo Motors / Drives
    Last Post: 10-04-2020, 11:31 AM
  2. Index group defined
    By BurrMan in forum BobCad-Cam
    Last Post: 07-09-2012, 10:22 PM
  3. freely defined table
    By LucyLou in forum HEIDENHAIN -> TNC
    Last Post: 09-30-2011, 08:29 PM
  4. user-defined hold
    By High Speed in forum HEIDENHAIN -> TNC
    Last Post: 07-05-2011, 05:37 PM
  5. How can I use the macro defined by DEFINE...AS
    By luffy27 in forum G-Code Programing
    Last Post: 03-24-2009, 11:35 AM
