586,121 active members*
3,061 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mini Mill slightly out of square - adjusting?
Results 1 to 15 of 15
    Hi guys, I have a slight squareness error on my new Haas Mini Mill, identified by a ballbar test and confirmed with a square. The X is 40 microns per meter out of square with Y. I was thinking of loosening up the X mounting to the Y blocks and twisting the axis slightly to bump it into perfect alignment, but I'm unsure of whether this amount of error would require me to loosen the ballnut on Y to allow the adjustment, or how difficult this process is in general. Has anyone done this before and is it a PITA? Is this error even worth correcting? The tech said it was within spec, but ideally I'd like this error below 20 microns.
    BTW, machine is fully levelled!
    15362
    Re: Haas Mini Mill slightly out of square - adjusting?
    Quote Originally Posted by MichaelKelly7104 View Post
    This would be in their test sheet and on them if this is out of spec, is this a new machine??
    Who did the test??
    You can't move the Linear Bearing Blocks, they are against a shoulder, and yes this would affect the Ball Nut alignment if you moved the linear Bearings
    So that would be around .001" out of square over its X-axis travel, you would have to hand scrape this to get it any better
    Mactec54
    Hi Mac, it is a new machine, yes. The Haas tech did the test and said he was pretty happy with the result, though he will obviously be biased to some extent. I think it should only be around 16 microns out over 400MM, so around 6 tenths of a thou - is this reasonable?
    Edit, I found this thread where the user realigned his machine on the blocks, is the mini mill different? https://www.cnczone.com/forums/haas-...xy-square.html
    Just to clarify, I don't actually intend to move the bearing blocks themselves, but the X axis which sits on top of the Y axis blocks, hope this makes sense.
    Thanks!
    15362
    Thanks!
    The X axis sits on the Y axes saddle there is no easy way to move either axis, the thread you referenced I would take that as fluff and someone who is not a machinist, they had the Linear Rails replaced and most likely where never installed perfectly
    Your Machine, the X axes sits on 4-Linear Bearing which are mounted on the top of the saddle and the Y axis Linear Bearings are mounted on the Bottom of the saddle all Linear Bearings are clamped against a machined register so to change any of this you would have to change how the Linear Bearing Block is clamped against the machined register, over that distance you would be looking at maybe 2 or 3 microns change, this would be a real challenge for someone that most likely does not have the equipment to do this job,, you would need AAA Granite Square at least 18" x 12" square to all faces to do the square test
    Most regular machining centers don't get any better than .0005" in positioning and cut accuracy so 6 tenths into the mix are not going to change much, of course you can cut parts much more accurate than this it just depends how skilled the person using the machine is
    Mactec54
    Thanks for the info Mac. In other words, leave it and enjoy it?
    15362
    What the other post shows and how they were able to change it, your Mini-Mill saddle is (1) piece so you can't do what they were showing, yes enjoy it if it causes you to have a part problem then it would be something to look at then
    Mactec54
    Thanks for the info!
    Question, I ran my very accurate level (0.02MM per 100CM) along the y axis and it appears there is a very slightly twist in the rails to the tune of 0.03MM per 100CM along the entire Y axis, is it worth adjusting the levelling feet to compensate? (if this will have any effect on the casting since it's a steel base machine) For reference it appears the front left foot is low. For the squareness, the X appears to be further forward on the right, and further back on the left. Would a lower left front foot cause this?
    if it's off level then it could throw things off a bit .
    If the machine was leveled correctly by the technician then it may be shifting the concrete if the floor isn't thick enough . Time and monitoring will tell . Overall they are light machines so it doesn't require an exceptional floor thickness , but I've dealt with some that were on thin concrete and leveling was a fairly regular occurrence on a couple mini's . Weather shifts will affect a bad floor greatly
    If the floor proves to be an issue then steel plates under each foot helps
    15362
    How are you checking the rails, are your way covers 0ff??
    This does sound strange if the table had been leveled by the tech when he did the install this all should be good, is the Table still good this is normally what you check, for the Y axis to be twisted that would throw the table off as well
    Mactec54
    No, I mean with the level sitting on the table perpendicular to X travel, and running the table in Y direction, there is a very small amount of twist evidenced by the bubble shifting about 1 to 1 and a half divisions on a 0.02MM/M scale. Very slight, but there. Shall I increase the height of the foot where it appears to drop?
    15362
    This would have shown up in the Ball-Bar test, I would say your machine has moved or it was not level to start with, the machine needs to be leveled in all both directions
    Did you reverse the level to see if it has the same reading
    Mactec54
    It wasn't the actual measurement that I was interested in, more so the change across the travel. The machine was only levelled last week and hasn't been used for machining yet. I did however calibrate my level beforehand. Bear in mind this is a very sensitive level - 0.02MM per 100CM. On a more typical level it does show basically perfect measurements.
    What would it have shown up as? Squareness error?
    15362
    So, you have a machine level that is 1000mm / 1meter long?? .0001" per 12'' is a sensitive level and is what the Tech would have used
    The circles would have been oblong if the machine was not level
    Mactec54
    Thanks for the info. Looking at the Renishaw QC-20 documentation an oblong circle also indicates a squareness error, which also suggests a levelling issue. The level is not 1 meter long, but the spec for its sensitivity is 0.02MM per meter per division, so about half the sensitivity per devision of the level you mention. I can definitely still see the error on my level. Would you tweak the foot slightly?
    15362
    If you are not happy with how the tech set it up, you should call them back for a redo
    Mactec54
  1. New Haas Mini mill
    By Ridehd in forum Haas Mills
    Last Post: 10-20-2013, 06:07 AM
  2. Adjusting BF20 to be square to table
    By outsider787 in forum Benchtop Machines
    Last Post: 07-31-2011, 03:14 PM
  3. New Haas Mini Mill
    By Hyrum in forum Haas Mills
    Last Post: 10-10-2010, 03:04 AM
  4. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
  5. Haas mini mill
    By pyroracing85 in forum Haas Mills
    Last Post: 05-12-2008, 01:33 AM
