Very new to CNC so looking forward to receiving expert opinions and advice from experienced members. Thank you
I'm looking into making guitar amp chassis and am researching a suitable pan box brake for bending chassis, bendable grade of aluminum, or galvanised steel.
I'm assuming will need to cut the metal flat on the bed of the machine then fold the metal, can't fold chassis then cut holes?
I'm thinking small scale one man, small business producing boutique amplifiers. What specs should a CNC machine have, options, software, ideally open source? I've read a little bit about lasers, spindles and stuff in general. To try and get a basic angle on all this stuff. Any advice on makes I might be looking at that would be able to cut holes in 16 gauge and accept size of chassis, would be appreciated.
Chassis size I'm thinking of.
Size: 483 x 238 x 70 mm material: 16 gauge 1.5mm steel
Size: 432 x 65 x 170 mm
Material: 2 mm Aluminum (AllMg3)
Have a look at attached screenshots to get an idea of what chassis would look like.
Thanks.
