586,111 active members*
3,517 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Did I messed my ball screw nut up?
    Jan 2019
    8
    So…
    A year ago I did an upgrade for my CNC with a new ball screw system. I bought it from the supplier in the UK, it was “made in EU ball screw”. I have paid quite of money.. Later on I found out that is just a china imported AliExpress stuff… At that point the website of that shop was down, they were out of business. No support there… The only thing I know - it’s 1210 ball screw, with 2.5mm bearing balls. No additional information.
    Few days ago I took apart one of them. The nut was moving friction-free on the screw, but it was dirty all around, just wanted to clean it. Did some research on how to repack this thing. I think I did it right. Took apart, cleaned it, greased it, put bearings back, I used some tube to mount it on the screw - wuolia! Now it does not move freely. I has friction and feels just not right. So I went with a process maybe 10 times again each time - the same result.
    This 1210 is really unpopular size. Ball nut in AliExpress cost ~€40 plus shipping (while 1604 in the same shop - €13)
    I have tried to find a high quality one here in the EU - with no success..
    Any thoughts?
    Cheers!
    15362
    Re: Did I messed my ball screw nut up?
    Quote Originally Posted by AUKURAS View Post
    So…
    Any thoughts?
    Cheers!
    Did you use a micrometer to measure the Balls quit often there are a big ball and one that is smaller, if yours are like this then you need to redo it, and correctly assemble them in order Big small Big small Etc.
    Why such a small Diameter Screw, 12mm is very wimpy the root diameter will be quite small, look on Ebay you will find these low grade cheap Ballscrews from China
    Mactec54
    Jan 2019
    8
    Yes, I did measure them with a professional micrometer, Few of them were 2.48 - 2.49 but the rest was exactly 2.50, so I don’t think that few smaller balls would make such a difference.
    Small diameter- because seller recommended so. I didn’t make enough research on my own, so I did trust a “professional”. I do regret actually, and already have a plan to replace it to 16mm.
    Thanks for an input!
    May 2020
    9
    Just dealt with this myself, ballscrews have multiple circuits make sure you are loading each circuit with the same count of balls
  1. Double ball nut worth it for long C7 grade rolled ball screw?
    By salukikev in forum Benchtop Machines
    Last Post: 09-02-2021, 07:48 PM
  2. Ball nut arbor size for 1605 ball screw
    By kdoney in forum MetalWork Discussion
    Last Post: 04-08-2020, 07:45 AM
  3. I think I messed this up - ball nut?
    By chris2112 in forum K2CNC
    Last Post: 01-07-2018, 08:30 PM
  4. Need help: Identify ball screw/ ball nut
    By RickOmatic in forum Uncategorised MetalWorking Machines
    Last Post: 07-27-2012, 10:04 PM
  5. Big Ball Screw & Ball Nut mistake.
    By Jack F in forum Uncategorised MetalWorking Machines
    Last Post: 04-29-2006, 04:53 AM
