I'm not a machinist. But I enjoy R/C boating and building what I can on my old atlas lathe.
Today I finally found the Hanson 3mm .5 die I needed to thread a 1/8" steel rod. I bought both items at Ace hardware. I know the die was intended to thread a 3mm rod, but I need a .125 shoulder for the project. This part replaces the glow engine propeller screw so that I may mount a flywheel and flex hex on the engine so its important that it is very true and centered.
My first attempt, the die started wrong and was off center. So I placed the die in the lathe and turned it by hand slowly. I used oil and backed off every few threads. It seemed to be going well until the rod broke. After a few choice words I removed the broken threaded rod from the die and tried to thread it into the engine crank. The die had worn so badly in the 2" I had used it I could not thread it in. The die was junk after only 2" of threading
What did I do wrong? And how do I go about making this part? Do I need a titanium nitride coated die? And who makes one?
Thanks before hand.
