586,082 active members*
3,613 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Citizen M20 Start Position Change (1999 Year)
    Jun 2021
    7
    Dear experts,
    Is there any way to change start position parameter in the machine? On my machine the turret is going to 180.0 (Z2) every cycle because its nominal start position is it. I lose about 7 seconds per one part.
    Help me please.
    Apr 2017
    7
    Re: Citizen M20 Start Position Change (1999 Year)
    Hi Cbayram7,
    I don't know if you can change the start position by parameter, but I don't think that is actually the reason that Z2 is moving at the beginning of your cycle. The Z2 movement is being caused by your mode change. I'm guessing you have a G600 or G630 at the top or bottom of your program (or another mode change). When the G600 mode is called the turret moves to the forward "home" position (close to the guide bushing) as part of this mode change, when the G630 mode is called the turret moves to the back "home" position. At mode changes you can add the W0 argument in $2 and that will keep your turret where it currently is (i.e. G600W0 or G630W0). Hope this helps.
    Jan 2013
    474
    Quote Originally Posted by cbayram7 View Post
    Dear experts,
    Help me please.
    I would have thought you have a G54 that you can use to set a safe axis position, then last line of the program G54 G0 G54 would send it to the ie G54 Z100 position.
    The must be a G54 explanation in your manual.
    Apr 2017
    7
    Quote Originally Posted by servtech View Post
    Hi Servtech,
    You have used G54 in your Citizen M type machines? That's news to me. In 10+ programming Citizen swiss machines (M, L, A types with both Mitsubishi and Fanuc controllers)I have never seen nor used G54 in my programs. The G6xx codes control modes and work coordinate systems in my experience.
    Jan 2013
    474
    Quote Originally Posted by Thunder27 View Post
    Hi Servtech,
    No, there wouldn't be zero shifts if the machine runs in absolute. Don't forget many macro's and m codes written by the manufacturer include ISO programming codes, so they are either not used or hidden.
    The point I was making was to check.
  1. Questions regarding Citizen A20 and Citizen M20
    By crackthesky51 in forum CITIZEN Machines
    Last Post: 01-24-2021, 12:27 PM
  2. Help Needed! How to change start position in RD Works
    By tperceval in forum Thunder Laser
    Last Post: 12-29-2016, 02:02 AM
  3. Citizen M20(Classic M20) turret A-axis programmin
    By OMS2010 in forum CNC Swiss Screw Machines
    Last Post: 08-13-2012, 09:06 PM
  4. Citizen Start Position L520....L720
    By chet470 in forum CNC Swiss Screw Machines
    Last Post: 06-27-2011, 07:25 PM
