603,810 active members*
3,033 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Using Moglice or Similar to Improve your Mill Ways?
Page 1 of 2 12
Results 1 to 20 of 21
    Mar 2005
    1673
    Hi all,
    Has anyone used or thought about using Moglice or similar to improve the performance of their mill?
    Having recently bought a Chinese Mill and gone/going to the trouble of improving the ways and dovetails by the means of scraping and lapping I have been wondering would it not be sensible to just apply Moglice for a superior finish at this stage?
    I have to be honest at this time I have only just scratched (no pun intended) the surface on the subject but from what I have seen so far it would make a big difference to the performance of even our hobby/prototype machines.
    I am now (when I can find the time) doing an in depth study of the use of products like Moglice and its application so during this the reason for not using it may become self evident but if others have been down this road and can shed some light on the subject it could save me a lot of time which could be better spent making chips.
    Please jump in if you can it will be appreciated,
    John
    Aug 2006
    1602
    Quote Originally Posted by Oldmanandhistoy View Post
    Hi all,
    John
    Hi John - there is a thread on here about someone who's done it to an X-2 (pardon my french ) : http://www.cnczone.com/forums/showth...ght=moglice+x2
    But to throw a pidgeon into a wood chipper, have you considered fitting linear rails to your table/ways like that amazing CNC'ed converted opti-vario ( http://www.cnczone.com/forums/showth...ti+cnc+heavily ) or the Industrial Hobbies mill that's been converted to linear rails on the Z/head ( http://www.cnczone.com/forums/showth...t=35961&page=3 ) ? If you can get spare tables etc. quite cheaply, you could presumably drill/mill them for the rails on your existing machine. Just a thought.
    Cheers.
    May 2005
    1810
    I was stumbling in here to comment, but I see Mr. Digits beat me to it!
    I have been using Moglice for many years in a variety of applications. It really is a seemingly uncelebrated way of very precise surface duplication that allows freedoms not frequently encouraged by other means. In other words - it's perfect for motion systems in my opinion.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Mar 2005
    1673
    Quote Originally Posted by digits View Post
    Cheers.
    Hi Digits,
    Thanks for the link to the X2 Moglice thread, I have searched but for some reason missed it. I will spend some time reading the thread.
    As for linear ball bearing rails; that idea has crossed my mind. Dynamic Stiffness (see here http://www.moglice.com/newsite/pages/straighttalk.html under “what is dynamic stiffness?”) needs more study before I would look down that road.
    I have not as yet looked into cost of products like Moglice but would hazard a guess it is a far cheaper route than bearing rails but I could be wrong.
    John
    Mar 2005
    1673
    Quote Originally Posted by mxtras View Post
    Scott
    Hi Scot,
    Thanks for your comment. From the little I have read so far it would certainly seem so.
    What I have seen so far about the coefficient of friction and that the gibs can be set with almost zero clearance to the dovetails tells me something about the benefits that can be gained from such a system.
    I would like to know more and that is the point of this thread along with more study.
    So if you have anymore gems of information stumble in any time you feel like it.:cheers: (group)
    John
    Sep 2007
    359
    Hi John.
    It's me again.
    Obviously i have retrofitted a cnc system same mill as the CNC Jnr.
    But what i have done is to also fit a one shot lube system the necessary ways were grooved to accept the oil this will have major benefits.
    1 Next to no wear.
    2 The oil when under load will eliminate slop. There isn't any one my machine as i also modded the taper gib system. Ask if anyone wants to know.
    3 The tables slide easy as anything.
    I can't believe no one else is doing it, the Asian machines are absolutely hopeless as they are.
    I looked at one link on here and the guy greased the table slides (nuts)
    Phil_H
    Mar 2005
    1673
    Quote Originally Posted by Phil_H View Post
    Hi John.
    It's me again.
    1 Next to no wear.
    Phil_H
    Hi Phil nice to see you again
    A one shot oil system is next on my list.
    I certainly cannot disagree with you on your “Asian machines” comment.
    So if I understood you’re post the use of Moglice is only necessary on the gibs in your opinion?
    John
    Sep 2007
    359
    Hi John.
    It was surprisingly difficult to find a supplier but i bought the system from a co called http://www.lubeline.co.uk.
    They were very helpful considering i didn't know what i wanted.
    The stuff is more sophisticated theses days you can get metering units to spread the oil to more or less places depending so you could even allow for minimal lubing to your ball nuts.
    IIRC i paid £200 for the complete kit which is money well spent mine is an 8 port system.
    I have no opinion on the Moglice sorry.
    Phil_H
    Mar 2005
    1673
    Please don't apologize It was my mistake I thought I read mogged not modded.
    Now I am going to ask what you did to the gibs?
    And thanks for the link also. I think I should go and lie down for a while and settle my brain.
    John
    May 2005
    1810
    John
    I would hope this is not what he meant. I read his comments several times and was unable to figure out what he was trying to say....
    Anyway - the beauty of using Moglice is that you can fixture your motion element into the exact position and then create the surface rather than scraping it in and attempting to achieve exact alignments. It's extremely easy to achieve whatever alignment you desire - one surface at a time.
    The injection pressure can move lighter parts, so rigidly fixture the components prior to injecting. If it is heavy, this is not as much of an issue but if the cavity is not vented freely, the injection forces can float even the heaviest elements.
    Conveying the numerous methods for utilizing Moglice material in text would take quite a while since every application has it's own unique requirements. Not to mention that there are many ways to accomplish any task. I need to update the mini-mill thread - pictures speak volumes!
    Scott
    May 2005
    1810
    As far as lube systems, I chose to construct my own. There were numerous reasons for building my own - adjustability, cost, versatility to name a few.
    Take a peek at this thread - http://www.cnczone.com/forums/showthread.php?t=10535 - see post #11.
    Scott
    Sep 2007
    359
    Scott
    My last comment was i had no opinion i was just saying what i had done.
    Hi John
    Ok my machine has taper gibs but the thread of the adjusting screw has a very course thread and it was also a very loose thread (nuts)
    "Expensive Quality Machines have a very fine thread and tight"
    So basicly one way the table went too loose the other way too tight.
    It would have been a nice project to tap out the castings make new screws etc but as i like to get the job done i made some big brass washers to fit in the gib strip and a brass bush behind that big fat washer so with a SHCS i tighten the screw the washer tightens onto the bush perfect fit in either direction when it gets loose facing of about .010 tightens the gib by about a gnats c**k as we say in the trade
    When i was adjusting the sliding fit i had the ball nuts disconnected and just got it so that it slid just the way i wanted.
    Made out of brass because it machines easily and does not rust.
    Phil_H
    Mar 2005
    1673
    Feeling much better now after my lie down just had a small case of information overload (doesn’t take much with my tiny brain lol).
    Thanks for the info on lube systems will get back to that after more Moglice investigations. Had a quick look at the UK website, looks promising. Scott nice job and not just the lube system.
    From first impressions from this thread so far I can see that this subject deserves more study. So I will leave it at that for now and get Googling for more information. If in the mean while anyone has more links on the subject that they think might be worth me looking through I would appreciate it.
    Scott thanks for getting me started with the information about techniques of application.
    Thanks again to all posters,
    John
    Mar 2005
    1673
    Hi again,
    While searching for a source of Moglice which as yet I have been unable to fine in the UK I came across mention of Turcite B (here if anyone is interested http://www.midlands-slideway-grinding.com/products.html ) . I know this product if by another name is used on the Tormach machines.
    So was wondering if anyone has had any experiences with Turcite B and could share your experiences?
    John
    May 2005
    1810
    Yup. Been there with Turcite, too.
    It's basically easy to work with but my preference is Moglice if you are jumping through the hoops anyway, but I could easily see where the Turcite might be more attractive to some folks.
    DeWitt is the only place that sells or distributes Moglice. For a European source of an identical product, Google "SKC". It's the same stuff essentially and is the eaxct product I have most of my Moglice experience with. Moglice and SKC handle and process the same for all intents and purposes.
    Scott
    Jul 2006
    1256
    John,Larry here.Sorry all my moglice pages were bookmarked and somehow were deleted.I filled out the info sheet to access their applications PDF's and received a message on my cell from a rep anxious to help,but but my cell "smoked"before getting the rep's name.They seem willing to assist the small guy.
    From memory possibly Practical Machinist,
    Moglice offered small kits to the small guys For ball nuts.The kit had enough for two ballnuts including cleaner and release agent for $50.
    Moglice also claims better damping on ways and ballscrews.Sounds like miracle juice.I will have to Re-Google to find the pages.
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Mar 2005
    1673
    Thanks again Scott for the SKC getting somewhere with that now.
    Larry thanks for looking in, your information may help guys on your side of the pond.
    I’m a little surprised this thread is not getting more attention; maybe I am over estimating the benefits of such products over cost?
    John
    Jul 2005
    969
    i have some interest but i am still trying to understand what it is, i mean from what i get its a form of putty or is it like a sort of liquid that leave a sort of hardened layer on your way and from the graph i got from a link in this thread the advantage seem to be pretty go if you have dovetail way
    The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
    Mar 2005
    1673
    Jul 2005
    969
    ok so basicly it acts as a sort of ''gap filler''
Page 1 of 2 12
  1. emco pc mill 50 & similar
    By hutchison in forum Benchtop Machines
    Last Post: 06-29-2025, 12:25 AM
  2. How to improve Jet Benchtop mill
    By dfro in forum Benchtop Machines
    Last Post: 04-17-2006, 03:04 AM
  3. Replies: 0
    Last Post: 10-01-2005, 11:40 PM
  4. Moglice Substitute?
    By cbcnc in forum Uncategorised MetalWorking Machines
    Last Post: 08-02-2003, 12:36 AM
  5. Moglice
    By NeoMoses in forum DNC Problems and Solutions
    Last Post: 06-02-2003, 12:00 AM
