586,357 active members*
2,957 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CNC (Mill / Lathe) Control Software (NC) > Are their controllers that output ASCII command(instead of pulse)?
    Sep 2007
    15
    I pursue robotics as hobby and these days there are 32-bit motor controllers that operate in 10+ MHz refresh rate that can perform amazing number of PID calculations per sec and this type of controllers can drive DC motor at very high rpm while maintaining tight speed regulation.
    Back to CNC, the cnc servo drive and controller combo I know is gecko g320/g340(drive) and Mach(controller) and no more (sorry I'm new to cnc)
    Anyways because Mach is limited to 48000 pulse/sec due to computer's motherboard clockspeed, high speed operation is difficult even with drive-side pulse multiplier (and pulse multiplier is not a good thing since it will multiply PID error too)
    So why not a cnc software that output ASCII commands? You know, software just sends out ASCII commands to make blabla number of steps in blabla pulse rate, then the drive's microcontroller performs the move accordingly. In other words, forget sending pulse at all because the controller sending out pulse is simply "a way" to give out message of step direction and rate, so replace it "ASCII way".
    In this way, 48000 pulse/sec limitation is easily overcome and higher rpm will be possible.
    Any drive equiped with 10 MHz 32 bit microcontroller will be capable of producing much higher PID refrash rate than needed for 48000 pulse/sec hence will be able to control the motor at much higher rate, which will result in not only an operability at higher rpm but also smoother rotation of motor(fully utilze high resolution of the encoder).
    Anyone aware of such cnc software or standalone controller that put out ASCII(or binary) command?
    Anyone aware of inexpensive servo drive that will accept such ASCII commands?
    I guess it has to be a controller+drive combo.
    Again my knowledge is limited to gecko and Mach, sorry.
    Thanks for your time.
    Feb 2007
    498
    i believe gecko offers an add on board,thr G-rex 100, i think which has anolog
    and can load a program into memory i believe,works with steppers or servo
    check it out,the only other inexpensive way is a rutex setup
    Sep 2007
    15
    Wow Rutex does that through serial interface and costs 150!
    Would you or anyone else know any more of these types? Please let me know any and all servo drive that is capable of receiving ASCII or binary commands instead of old-fashioned pulse trains! (willing to spend upto $250)
    THANKS!
    PS
    Wouldn't it be nice if ULI makes one?
  1. why pulse the servo drive? (why not ASCII/binary it?)
    By JasonCampbell in forum Servo Motors / Drives
    Last Post: 09-27-2007, 05:49 AM
  2. ascii data filtering using Surfcam?
    By casey in forum Uncategorised CAM Discussion
    Last Post: 05-15-2007, 01:57 AM
  3. Unfit Pulse Of Pulse Coder Alarm
    By Crashmaster in forum DNC Problems and Solutions
    Last Post: 04-23-2007, 03:55 PM
  4. ASCII to .dwg conversion?
    By rc30fan in forum Uncategorised CAM Discussion
    Last Post: 03-31-2005, 11:16 PM
  5. Other controllers that output step/direction?
    By cn00728 in forum CNC Machine Related Electronics
    Last Post: 02-02-2005, 08:30 PM
