603,370 active members*
3,337 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 11T Soft limit troubles on Slant-1
    Sep 2007
    5
    I am having trouble overriding the software limits of the machine to drive the X axis to a normal position. The X axis is nowhere near the physical limit of the slide. I think the batteries were almost if not completely dead in this machine when I started working on it and had some success with sending a program and doing some manual machining but upon restart of the machine this morning I was able to zero the Z slide fine but the X slide would only move @ an inch off the center of the lathe. The machine cordnance says about an inch on the display for the X slide also. Any help would be appreciated, thanks
    Jun 2005
    200
    Position both Z and X middle of their strokes... Power down the machine... Prior to turning on the control, hold in the "P" & "Can" keys and keep them pressed until the control powers up all the way. Now do a Zero Return...
    JR Walcott
    Georgia Machine Tool Resources, LLC
    Sep 2007
    5
    Thank you for the response.
  1. Fanuc 6T RS232 Troubles
    By Bent82 in forum Fanuc
    Last Post: 02-06-2007, 07:57 PM
  2. fanuc 0m-B troubles
    By sammer003 in forum DNC Problems and Solutions
    Last Post: 01-25-2007, 12:32 PM
  3. Slant 3/ Fanuc 11te Rs232 Info???????
    By metlshpr in forum Fanuc
    Last Post: 12-31-2006, 12:28 AM
  4. Fanuc OM soft limits reset?
    By CNC Biker in forum Fanuc
    Last Post: 04-26-2006, 03:33 AM
