603,932 active members*
4,634 visitors online*
    Feb 2023
    Collet Size Range
    I have never understood collet range sizes. For example,
    3/32 Collet recommended range: .054 - .093"
    1/8 Collet recommended range: .086 - .125"
    However, if I try to put a .098" drill in a 1/8" collet, it clamps down unevenly. I can play around with it enough to make it visually look even, but that's not practical when needing to set this tool up several times a week by a variety of people. It seems like it is better for those tools near the small size range to actually drop down a collet size even if that does force the collet open a little. I was wondering what some other people's thoughts might be on this topic.
    Jan 2013
    474
    Quote Originally Posted by HTR718 View Post
    Depends on the collet, rubberflex collets have a bigger range than all steel collets. Always best to aim for collet where material is mid range.
    Jan 2013
    126
    Re: Collet Size Range
    Why not get a 7/64 collet. With collets just because the range is that large does not mean you should use the full range
  1. Collet Size vs. Bit Size
    By TommyS in forum Chinese Machines
    Last Post: 10-28-2017, 01:57 AM
  2. TTS Collet Size
    By R.M.S. in forum Benchtop Machines
    Last Post: 01-28-2014, 12:20 AM
  3. Collet size ?
    By speedtwin69 in forum Taig Mills / Lathes
    Last Post: 01-15-2012, 04:21 AM
  4. Need help with collet size: PC Mill -30
    By oxford in forum EMCO Mills
    Last Post: 04-12-2010, 03:41 AM
  5. What is this collet size?
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 06-06-2004, 07:07 PM
