588,217 active members*
4,120 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Have my Steepers Assumed Room Tempeture Too? (DIED)
    Sep 2003
    1475
    Question Have my Steepers Assumed Room Tempeture Too? (DIED)
    Because of my miswiring between the Xylotex stepper controllers and the steppers, my stepper controllers have died.
    I have stripped everything out and am starting over. I think my steppers are OK but I need someone to give me a professional opinion.
    If I measure across both coils on each stepper I get aproximately the same reading on all steppers, for each coil.
    I didn't find any shorts between coils, nor between any coil and the case.
    Is there any further test I could perform before I call them good and connect them to the new stepper drivers?
    Jun 2003
    3312
    I doubt you damaged your motors. But, how did you miswire that damaged your controller board?
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Sep 2003
    1475
    Controller - Stepper connections
    Quote Originally Posted by pminmo View Post
    Here are the motor connections that I used:
    A# on Board is connected to Red 1-2 on Stepper
    A on Board is connected to Black 3.4 on Stepper
    B on Board is connected to White 5-6 on Stepper
    B# on Board is connected to Green 7-8 on Stepper
    This is the link from Scorcheror, telling me the correct connections:
    SORCHEROR
    ok mr chips,i got it your hooked up wrong at the board,here how it should be
    A on the board=1+2
    A# on the board=5+6
    B on the board=3+4
    B# on the board=7+8
    im not sure what colors you used but stick with the numbers,i got them from powermax
  1. Building CNC Plasma table - Machinist Died!!
    By Crayola in forum Waterjet General Topics
    Last Post: 02-06-2007, 05:38 AM
  2. Help! Building CNC Plasma table and Machinist died!
    By Crayola in forum MetalWork Discussion
    Last Post: 02-05-2007, 09:06 PM
  3. Help, my Geckos may have died!
    By bkkpool in forum Gecko Drives
    Last Post: 10-30-2006, 08:30 PM
  4. Mill drive motor died.
    By devinchi in forum Shopmaster/Shoptask
    Last Post: 05-14-2006, 06:47 AM
  5. Slow Steepers - newbie
    By jdemille in forum Mach Software (ArtSoft software)
    Last Post: 01-03-2006, 01:04 AM
