603,874 active members*
7,715 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Help..Stuck at relay ext dc voltage missing but dc voltage OK ?
Page 1 of 2 12
Results 1 to 20 of 27
    Sep 2007
    69
    I have a series 2 interact 2. I have rebuilt the failed dc voltage regulator. I now have both the unregulated 29-30 volts dc and the 24 volts regulated....but the dang MDI control (Heidenhain 151) is still not happy and wont let me past this error message....what am I missing....please list any thoughts you have on what would cause this error prompt if not the regulator.
    1121
    re
    follow the emo string
    Sep 2007
    69
    Ya Thanks gus......where would I find that piece of string and what color is it ??? 8-O........LoL......Unfortunately I don"t have a flow chart for the emergency
    off circuit.......so I am not fully certain that I have tested all the components on the circuit.....all the limits are of course obvious. But I am not certain of all the other checks this control does yet.....oil...air pressure....etc.....I gotta be overlooking one somewhere...........common Gus........ you said this would be easy......8-)
    May 2004
    402
    Did the 24v DC fail in a mode that put significantly higher, or maybe AC, volts onto the TNC - if so has the 24v input on the TNC let the magic smoke out?
    Andrew Mawson
    East Sussex, UK
    1121
    It's right there on the wiring diagram.
    I'm sorry, but a 24v issue is pretty easy to trace
    1121
    vertical line "11" on the diagram. the power enable button bypasses some of it. look for 24 volts at every single point.
    respond AFTER you have done that
    Nov 2004
    3028
    Just in case, I found a scan of the wiring.
    George
    Attached Files Attached Files
    Nov 2006
    925
    According to George`s PDF the e-stop line is 110v.Nice clear drawing that, better than the one in the book.
    Mark.
    1121
    re
    Nope 24V
    Nov 2006
    925
    Gus
    Going by the schematic that George posted the E-stop buttons are quite clearly 110v
    Sep 2007
    69
    Aaarrrrggggggg
    Quote Originally Posted by gus View Post
    GUS...BUDDYYY >>>PALLLL I cant read the schematic ? I can not see the text, it is too low a res....remember you were going to send me a hi res copy ???.....I dont have a manual for this machine...I do not have a "readable" copy of the dc circuit............and sadly if it is as easy as you imply....the MDI dc voltage sensing circuit is cooked...remember I dont know why they chopped this machine up....
    Sep 2007
    69
    THANKS GEORGE this is the first bridgeport schematic I have been able to actually READ......yay THANK YOU>>>>>
    Sep 2007
    69
    Another point guys.....dont forget where I am...eh...CANADA........this is a 600 volt machine.....so I still do not have a fully accurate diagram.....I have found circuits on my mill that do NOT appear in ANY schematic I have seen so far...including the most recent sent by George "machintek"
    Sep 2007
    69
    Line 11 ?????????????????????
    Gus.....please tell me you mean line 116. Line 116 Unregulated 30v dc to various switches AND to regulator........Line 90 from reg to ground.....and line 65 from regulator with 24v dc to MDI unit ?
    Nov 2006
    925
    Dirky,here`s a link to the service manual for the 151.I notice the inputs are protected by what Heid call fuse resistors.Worth a look at.
    http://filebase.heidenhain.de/doku/o...b/sa151155.pdf
    Mark.
    1121
    I was mistaken Gridley, it is in fact 110, nonetheless it is where he must start to find the lost 24v.
    Sep 2007
    69
    Thanks for the link Mark....Yes I see that...they have many of the cicuits protected with a 47ohm fuse/resistor.....this is exactly what I expect to find....
    Sep 2007
    69
    respond AFTER you have done that[/QUOTE]
    OUCH kaboom smokin meter....hows that for a response.
    Sep 2007
    69
    just screwin around Gus.....thanks for the heads up
    I will look into all the points on that circuit soon as Im home....
    Nov 2006
    925
    Dirky,
    vertical line 11 on the drawing is 110 volts.When you get to the stage of having the "ext 24v missing" message is 2CR and 10CR energised?
    10CR coil is energised with 24v dc and 2CR is 110v ac.
    Provided the e-stop buttons are out,the oil level switch is made and the fuse on the 110v line and the fuses supplying the transformer are ok 2CR should be energised.
    CR10 needs 24v dc from the TNC to energise it.
    Can you check this?
    Mark.
Page 1 of 2 12
  1. BT Interact 412 - RELAY EXT. DC VOLTAGE MISSING
    By Zhales in forum Bridgeport / Hardinge Mills
    Last Post: 10-19-2017, 03:19 PM
  2. relay ext dc voltage missing
    By hdts in forum Bridgeport / Hardinge Mills
    Last Post: 01-02-2015, 12:22 PM
  3. relay ext. dc voltage missing error on tnc 150 B
    By M535 in forum Bridgeport / Hardinge Mills
    Last Post: 05-07-2013, 12:20 PM
  4. relay ext dc voltage missing in TNC 351
    By moghul in forum Bridgeport / Hardinge Mills
    Last Post: 01-29-2013, 02:03 AM
  5. Relay ext, dc voltage missing
    By fastcarl in forum Bridgeport / Hardinge Mills
    Last Post: 11-18-2010, 01:57 PM
