586,104 active members*
3,403 visitors online*
    Mar 2004
    43
    gcode to gcode converter
    Is there any programs that will change gcode for one machine into gcode for another that doesnt have all the same commands?
    Apr 2003
    1876
    None that I'm aware of. Have you tried a google search? A lot of it will depend on what needs to be changed.
    You could write a script (VBS) to read the original then change any codes you need via the REPLACE() function.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Mar 2004
    43
    what Im trying to do is write programs with canned cycles that I can convert to code that my machine will understand.
    Probably something theres not much of a need for but I dont have a cam for lathe stuff and I wanted to see if there was something like this so I could get a little break doing the programs manually.
    Apr 2003
    1876
    If the changes aren't too significant, I'll see if I can come up with a quick script to help you out. Let me know what you're going "from" and what you're going "to", and I'll let you know.
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Jun 2003
    205
    Arrow Conversion Software
    Take a look at KipwareXC ... www.kentechinc.com
  1. Gerber RS724X to Gcode Converter???
    By nickzl in forum G-Code Programing
    Last Post: 01-07-2012, 11:37 AM
  2. Gerber RS724X to Gcode Converter???
    By creative_mind in forum Uncategorised CAM Discussion
    Last Post: 10-26-2009, 05:44 PM
  3. Is it possible to get a gcode into Rhino
    By MrBean in forum Rhino 3D
    Last Post: 04-03-2005, 01:41 PM
  4. 3phase servo retrofit
    By whiteriver in forum Servo Motors / Drives
    Last Post: 02-07-2005, 04:27 AM
  5. Gcode verify autocad plugin
    By balsaman in forum Uncategorised CAM Discussion
    Last Post: 10-31-2003, 06:22 PM
