603,864 active members*
3,710 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > extending THK rails, rail alignment
    May 2004
    60
    I purchased some HSR20 rails off ebay new-in-box. Each box has a ~47" and a ~19" rail and two slides. One end is precision ground flat and the other has like a thick layer of paint on it. I'm planning on using them for a 4' x 4' gantry.
    Laying on a table if I but one rail up against the other I can slide the block from one rail to the other without issue. However, I made a wood mockup to measure the sliding force and I'm finding it nearly impossible to get them perfectly lined up. So:
    1) Are these rails designed to be 'linked' or 'extended'??
    2) The misalignement is small, seems insignificant but yet persists. Are my concerns realistic that once I get these mounted on some 80/20 aluminum extrusions that I may still have alignement issues? If so, how do I line these up??
    Ahhh, why can't economies of scale work in the mechanical world like in portable electronics where small is expensive and big is cheap????
    Thanks for any help.
    Cliff
    May 2003
    340
    1) no
    2) it will likely cause wear. Certainly THK would turn in there grave if they had one.
  1. Joining two THK SHS15 rails
    By PEU in forum DIY CNC Router Table Machines
    Last Post: 05-25-2005, 02:16 AM
  2. question about thk rail mounting
    By mwp in forum DIY CNC Router Table Machines
    Last Post: 03-10-2005, 07:10 AM
  3. How close can I space THK rails?
    By bgolash in forum DIY CNC Router Table Machines
    Last Post: 12-31-2004, 06:13 AM
  4. Bolt spacing on THK rail?
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 07-25-2004, 12:36 AM
  5. Wrong THK rail - Help!
    Last Post: 07-17-2004, 07:26 PM
