586,116 active members*
3,322 visitors online*
    May 2007
    4
    ESAB controller
    Does anyone run the new controllers from ESAB for their plasma cutting?
    I have few questions concerning the technology record options,
    -dist. to end of line
    -dist. after line
    -THC after corner
    THX
    Mar 2004
    1661
    Why don't you call them directly?
    Jan 2006
    36
    I'm an operator...
    I operate two Esab cutting machines, might be able to help,... but might have to be a bit more specific....
    Feb 2006
    1260
    Quote Originally Posted by svenakela View Post
    My guess would be you have to pay either by the Min. or a lump sum per year for tech help. However that is just a guess......
    If it works.....Don't fix it!
    Oct 2008
    5
    ESAB Controller
    The Parameters you are looking at pertain to the firing of the Plasma Torch itself.
    Distance to end of line.== Lets Say Your Cutting A Square. You've cut 3 sides, Now, How far before you reach your final points of the intersecting lines do you want to extinguish the Arc. (very handy if cutting Gauge Material)
    Distance after line.== same Square scenario. If you are cutting say 1" material your arc is lagging the torch tip by a few degrees. Keeping the Arc ON after you've reached your intersecting lines will completely cut out the part. If the Arc Extinguished as soon as you cross that point you'd be left with a Tab.
    THC after Corner. THC is you Torch Height Control.(by sampling the Arc Voltage we can determine the correct torch height based on a setpoint . Because we deccelerate and accelerate out of corners we have to Disable THC diring that time. This parameter allows you to tell the system when to reinitialize the THC function.
    Hope this helps
  1. Esab Operators? Columbus software?
    By Oakley1975 in forum Waterjet General Topics
    Last Post: 12-06-2022, 02:01 PM
  2. Please Help ESAB AUto Path 750
    By pcasey in forum DNC Problems and Solutions
    Last Post: 10-23-2008, 10:53 AM
  3. Looking for ESAB 875 Plasma Consumables
    By robo_plasma in forum Waterjet General Topics
    Last Post: 01-10-2007, 02:51 AM
  4. ESAB Auto-Pathgx machine
    By woodythx13 in forum Waterjet General Topics
    Last Post: 03-30-2006, 02:43 AM
  5. Esab Auto-pathgx Machine
    By woodythx13 in forum Commercial CNC Wood Routers
    Last Post: 03-30-2006, 02:35 AM
