586,121 active members*
3,643 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Biesse > Biesse Rover 20 Drills hitting clamps
    Jun 2017
    8
    Unhappy Biesse Rover 20 Drills hitting clamps
    I have a Biesse Rover 20 running on NC500. It is currently set up to run clamping only, no vaccum. When drilling the bits are only about 3mm above the panel while it moves into position, so they are hitting clamps.
    Can anyone explain to me how to adjust the distance the bits move above the material? Can it be done?
    Apr 2018
    37
    Re: Biesse Rover 20 Drills hitting clamps
    Change the "Safety" value in the drills. It's probably 20mm by default
    F5 -> ENTER -> F9 -> PASSW:111 -> ENTER 2x
  1. Biesse Rover S FT - NEED HELP PLEASE
    By eoinquinn in forum Biesse
    Last Post: 08-07-2021, 07:18 PM
  2. Replies: 13
    Last Post: 10-21-2017, 06:02 PM
  3. Biesse Techno drills?
    By Foxspeed in forum CNC Machining Centers
    Last Post: 11-28-2016, 01:04 PM
  4. ROVER 13S NC400 - DXF IMPORT - SIDE DRILLS DEPTH
    By iborov in forum CNC Machining Centers
    Last Post: 04-03-2013, 08:03 AM
  5. Biesse Rover C
    By Dogfart in forum CNC Machining Centers
    Last Post: 06-07-2009, 05:17 PM
